Old 12-12-2013, 06:15 PM   #1
jasonda
front differential widths ????
I was wandering if anyone of you guys who are much smarter than I could tell me if the front differential track or width is the same on a 1968 k20 as it would be on a 1975 k20.
jasonda is offline   Reply With Quote
Old 12-12-2013, 07:57 PM   #2
obijuan
Re: front differential widths ????
67.5" on the 73+axles and the older should be the same if we're talking discs.
obijuan is offline   Reply With Quote
Old 12-13-2013, 08:47 AM   #3
You're talking about the axle,or more accurately axle assembly. But,when you say axle people will get it. The differential is the center section of the axle that contains the carrier assembly incl the ring & pinion.
I don't have the exact width measurements,but any GM solid axle is the same approximate width...all interchangeable. if there is any difference it won't matter
