Old 12-16-2003, 01:51 PM   #1
orange72350
orange72350's Avatar
Power Steering Squeal
Ever since i swapped engines in my trcuk, the power steering sounds horrible. While the enignes were being swapped, the belts sat outside in the cold for apporixamltey 4 weeks. will this ruin a belt? also, i screwed up and forgot to plug the top inlet to the power steering box while the truck sat outside. The pump is nearly new, but not sure about the age of the gear box. Will abelt squeal more when load is put on the power steering pump? when we started up the engine, my buddy ran the power steering dry for nealry 5 minutes. i wasnt there when it happened, but will that ruin a pump? i hope not, cuase that was a 100 dollar pump. Anways, any help is much appreciated. Tahnx guys
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 12-16-2003, 01:56 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
power steering pumps to an extent with a load on them should not squeal as long as the belts are good and they are also tight. As far as running it for only five minutes without any fluid I would hope it wouldn't fry it that fast but it is possible. The best thing to do is fill it up to the correct level and try it. The belts being left outside for 4 weeks could cause a problem if it was really cold. I would inspect them for any frays or dry cracking. If there cracked go ahead and replace them. Where you left your top connections on your steering gear box unplugged did you leave the hood down on the truck or was it in direct contact with the elements?
I would venture to say you should still be safe with your power steering pump and gear box, but I'd doublecheck the belts and then make sure there tight. Good luck
WRMZ71 is offline   Reply With Quote
Old 12-16-2003, 01:59 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Pump should be okay. I think the proper procedure for getting rid of the squeal (getting all the air out of the system) is to fill the reservior, jack the front end of the truck off the ground, then turn the wheel somewhat slowly from side to side until the squeal/air is gone.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-16-2003, 06:40 PM   #4
WRMZ71
WRMZ71's Avatar
Air in the system should not cause a squeal. Air in the system will cause the whining sound. The procedure that you said is correct but you don't necessarily have to put the front tires off the ground, it just helps. Squealing comes from four things, bad belts, loose belts, too tight of belts, or a bad pump.
Old 12-16-2003, 07:55 PM   #5
ckhd
ckhd's Avatar
Belts are cheap. Replace it and see if it fixes it.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 12-17-2003, 12:23 AM   #6
dinnut
dinnut's Avatar
ive ran without fluid for quite a while. my box leaks and i am constantly putting fluid in it
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-17-2003, 12:42 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Air could cause a chirping/high pitched graoning that could be mistaken for squeeling.
I doubt the belt got damaged from the cold...it woulda been outside anyways, just under the hood.
Old 12-17-2003, 03:13 AM   #8
blazer1971
If the belts were too loose or too tight they can crystalize on the inner surface in a matter of minutes causing the belts to squeal even after correct tension is appplied.
blazer1971 is offline   Reply With Quote
