How Do You Prep Inside Frame Holes
TEAM:
I have prepped the front end of my frame for primer, but do not feel the edges of all the holes in the frame are paint ready. How do you normally address these holes in preparation? Should I just roll some sand paper and use a finger? Mahalo!
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
Re: How Do You Prep Inside Frame Holes
te smaller ones you mite run a correct size drill bit thru first. they make small flapper wheels for your drill too. or glue a piece of sand paper to a wood dowel. just some ideas.
#3 | |
Anyone ever see something cone shape for wire wheels?
If you have a dremel tool, this little 1/2" brush might be a solution:
A wire battery post & terminal cleaner tool works good too....
#6 | |
Great idea. Have one laying around, just didn't event think about it.
Any welding supply house will have coned wirewheels
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
Unfamiliar with welding supply houses. What are some names of such suppliers? If there are nation wide options.
#9 | |
Ask me how I know............... ![]() cheers JohnG |
