Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-18-2013, 03:41 AM   #276
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: My build thread.. 63 LS powered C10
Yes!!!
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-18-2013, 06:09 AM   #277
softballnrd27
I plan to boost the 5.3 and once I figure out all the ins and outs of turbos and "electronic" tuning I plan to build a 427 LSX based with a big single to do the same things you are talking about.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-18-2013, 09:01 AM   #278
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
SO the 4l80e you have its not strong enough for that engine an its for sale right?? its will hold a mild 850 or so .. yea wrap it with a bow for my christmas gift!!!
Twin hair dryers right on nothing better than boost.
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-18-2013, 12:14 PM   #279
Super73
Super73's Avatar
Steve,
I sold my stock 80e years ago when I put the glide in the truck. Sorry bud..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-18-2013, 02:22 PM   #280
tinydb84
tinydb84's Avatar
Who is building your hot and cold side piping? I love the idea of going turbo but don't know how much all the piping would set me back.
David
Instagram: myfabguy
Old 12-18-2013, 04:25 PM   #281
Super73
Super73's Avatar
I plan on doing it. Check out Columbia River Mandrel. They even have 2.5" or 3" to T4 adapters.
Old 12-18-2013, 05:43 PM   #282
slowtruck
You shouldn't need anything bigger than 2.25-2.5 going to the turbos. A lot of people have been doing 2.25 as they say it helps with a quicker spool up and doesn't hurt top end power.
If you have never drove a good turbocharge engine I'm sure after you make your first clean run under boost you will never want anything else. I had a 76mm set at 10psi on an lt1 383 and loved it over a 200hp of n2o and that's why I have twin 61's for the 383 going into my truck.
slowtruck is offline   Reply With Quote
Old 12-20-2013, 11:07 PM   #283
Super73
Super73's Avatar
I am told dual 2.5" will support about 2,500hp on a hotside.
I am going to be using Columbia Mandrel for my piping. Since my heads have a 1 3/4 exhaust cross section, I need to go 1 7/8 OD primaries. CM makes a 1 7/8 x 4 collector to a 2.5" but nothing smaller. This is what I will be using with their 2.5" to T4 adapter. The turbos are more or less going to sit above the control arms so there won't be a lot of tubing anyway. The collector is going to be welded directly to the adapter and mounted to the turbo.
With the 418" motor I don't think 1 7/8" and 2.5" up pipe will slow spool that much being how close to the head port they will be. Plus, I plan on spinning 7,400+ and still using a decent sized converter. In addition I have a t-brake and 2 step. I have no doubt this thing will spool plenty fast.
Old 12-20-2013, 11:51 PM   #284
slowtruck
With what you have going on that's a understatement! Lol
I didn't know what you knew about turbo setups and just didn't wanted you to still be thinking like it was a NA setup where bigger is always better.
Old 12-21-2013, 01:38 AM   #285
Super73
Super73's Avatar
Turbo tech is obviously moving fast! Cam selection is still a bit of black magic though. I have my thought there too. But will find out some day.
Old 12-21-2013, 01:59 PM   #286
Marv D
Registered Truck Offender
Marv D's Avatar
That is really surprising to me that they are moving to such a small hot side when you start building big flow volumes like this. Just seems like at some point the spool-up advantage is going to lay waste to the potential total flow. I mean only so much is going to flow out even under presure and exhaust being a expanding gas as it leaves the motor. I know it is a whole new ball game when you start force feeding the induction with 10-15+psi. and exhaust back pressure becomes more and more insignificant. But there has to be a serious WALL where you can only stuff 15 pounds of $#!+ in a 5 gallon bucket until it backs up in the pipe.
Turbo tech is definately WAY out of my arena,, I have a buddy who is a Mechanical specializing in pump stations. Maybe he can 'splain' it to this ol dummy N/A guy in a old-school way i can rationalize.
Is this scenario hold true in a max-effort TT motor, or more towards street-strip-driver TT motors???
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-21-2013, 10:59 PM   #287
Super73
Super73's Avatar
Marv,
One thing I have learned by reading through some of the BS, gasses in a forced induction system are much hotter. Gasses at this temp move much faster and you can get more volume through a smaller pipe as temp goes up. So keep it smaller than you'd think to the turbo. After that, as the gasses cool, they expand and a big huge 5" pipe can't hurt.
Things I don't know for certain:
Stepping piping after turbo has benifits.. 3" to 3.5" to 4" to 5"
Overlap is deemed bad in turbo set ups, yet negative or 0* overlap does you no good. Seems like somewhere from 10-20* @ 0.050 is good.
IVO BTDC is not desirable
How does IVC affect desired RPM?
Is a large split with big exhaust bias a pro or con?
Compression isn't always a bad thing, I will be running aprox 10.5-1 static.
BTW did you see the Hyd Roller write up in Car Craft this month? When I read it I thought of you
Old 12-22-2013, 06:00 PM   #288
slowtruck
If you guys like to read a lot you should check out the book "Maximum Boost" by Corky Bell, it has a lot of good info and theory.
Maximum Boost: Designing, Testing, and Installing... Maximum Boost: Designing, Testing, and Installing...
For help on the cam questions you need to get with LilJohn on Yellowbullet or ls1tech, he's good with stuff like that!
Old 12-22-2013, 08:51 PM   #289
Super73
Super73's Avatar
I most likely will not be using eith lil john nor martin at Tick. Nothing against either really.
Old 12-23-2013, 02:02 AM   #290
KQQL IT
At the body shop.
KQQL IT's Avatar
Nate I'm sure could.
KQQL IT is online now   Reply With Quote
Old 12-24-2013, 01:48 AM   #291
BigDan3131
BigDan3131's Avatar
You shouldn't have to rev it that high to make that level of power especially with a pair of large turbo's. You really should be spending your reading time at www.theturboforums.com there is so much info there but sometimes you get too many answers that just doesn't seem to be right and when that happens I go to the manufactures websites instead. I only plan to run 5 pounds of boost thru a single GT45 ebay turbo on a bone stock 5.3L truck motor thru a carb and instead of an air to air intercooler I plan to run a water to air setup instead. You might want to think about keeping some of the N20 stuff for race day to spool up the turbo's faster.
This site has decent pricing on what they sell: http://www.frozenboost.com/index.php...119a50dbb7fa16 for the accessories.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-06-2014, 01:58 AM   #292
softballnrd27
Any new updates?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 02-06-2014, 03:00 AM   #293
Super73
Super73's Avatar
Updated the 1/4 thread sticky.. new times in Sig.
Old 02-06-2014, 10:46 AM   #294
Wasted Income
Boosted Member
Wasted Income's Avatar
An A2W at only 5 psi? At 5 psi you shouldn't really need an intercooler at all. I have my water/meth set to turn on at higher than 5 psi. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-06-2014, 11:54 AM   #295
prostreet1967
prostreet1967's Avatar
looking forward to seeing this. ive been working on my turbo build slowly but end up working on other peoples cars more than my own. could use the motivation!
prostreet1967 is offline   Reply With Quote
Old 02-06-2014, 12:30 PM   #296
Super73
Super73's Avatar
I won't be starting the turbo build for some time. There are a few things I want to change before I even think about it, and all of those cost money
The biggest thing I want to change before the turbos is the front suspension. I'd hate to fab up piping only to have it hit the new set up I plan on going with.
The other items are:
Trans - back to a built 80E (I think)
Rear - to a 9" which I am in the process of
But we are going to keep leaning on this thing until then.
Old 02-06-2014, 01:40 PM   #297
softballnrd27
Sweet times, how fast do you want to go?
I plan to use a gt45 on my 5.3 and shoot for mid to low 10s. I am going to "learn" with cheaper parts and then build a real motor and use real turbo(s) and shoot for low 9s and all the while driving to and from the strip and anywhere I want to during the week with good gas mileage. Going to try and use stock rear suspension w/caltracs and bolt-in IFS front suspension, 4l80e and 9" with 325/50/15 drag radials.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 02-06-2014, 01:41 PM   #298
softballnrd27
Don't take this the wrong way bc I love the look of the truck but are you going to ever do paint and body work on the truck? I go back and forth on mine all the time when it comes to paint and body. I like the "beater" look but then I see some pretty trucks and well you know.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 02-07-2014, 01:38 AM   #299
BigDan3131
BigDan3131's Avatar
I know I don't need the A to W intercooler but if I decide to sell my ten second El Camino later on I will already be set. Besides, it will help the most on the road trips to Cali I plan to make over the mountains and the desert heat so any little extra drop in temps will help.
Old 02-07-2014, 11:33 AM   #300
prostreet1967
stock48 got my turbo and cam specd for what i wanna run. same setup in a mustang went 5.6x and was running out of fuel. stock48's nova went 8.3x in quarter with same setup. very cool guy. i tried martin and john and got blown off.
