Old 12-15-2013, 01:56 PM   #26
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
xpickup is offline   Reply With Quote
Old 12-15-2013, 02:04 PM   #27
youngrodder
youngrodder's Avatar
Re: 47 Step van
Looks great Shannon. Working outside in the winter. Your a warrior. It is hard to get motivated when it is cold out. Here in MI we have gotten dump with snow.
Keep up the pics
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-15-2013, 08:22 PM   #28
99 to Life
99 to Life's Avatar
Re: 47 Step van
that looks factory quality, as always. yeah this snow is cramping my game. We got like 12" not long ago, mostly melted, then just got another 6" atleast. 2x4 s10 is getting a work out.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-15-2013, 08:49 PM   #29
xpickup
xpickup's Avatar
Re: 47 Step van
youngrodder, thank you, it has been cold as he'll and snowy. Last weekend I was working underneath it while it was snowing. Then Friday I was working on the exhaust and the snow was melting and then I must have rolled in it i do not know how many times. I am over winter already and it has not even started yet!
99 to Life, thank you, it snowed here the past 2 weekends. It stinks working outside but oh well. Funny thing is that I have not even put my 4x4 dually in 4 wheel drive yet. I am still trying to work out the bugs on the lowered one yet. Hopefully over my Christmas vacation I can make some time for it.
Shannon
Old 12-17-2013, 11:14 PM   #30
xpickup
xpickup's Avatar
Re: 47 Step van
I started working on the aluminum roll pan tonight. It will have a 1 inch recessed area where the exhaust will come out. I had to make it wider so that I could cut out the rot on the one side. Both ends are stepped so that it can be riveted to the body and it will fit up right under the rear doors. Friday I will TIG weld it together and hopefully finish the exhaust if it does not rain or snow.
This is the second time writing this because when I attached the pictures it wiped out what I wrote. Does anyone else have this problem? I usually write in one post and post pictures in another then I do not lose what I wrote!
Shannon
Old 12-17-2013, 11:18 PM   #31
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-17-2013, 11:20 PM   #32
youngrodder
Re: 47 Step van
Very cool. I like the way that looks. It will be nice to see it on the van.
Marc
Old 12-18-2013, 01:02 AM   #33
skymangs
skymangs's Avatar
Re: 47 Step van
This is gonna be Cool. I'm along for the ride!
skymangs is offline   Reply With Quote
Old 12-18-2013, 10:09 AM   #34
69CST-V
69CST-V's Avatar
Re: 47 Step van
Better late than never. Shannon you take on some cool projects.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-18-2013, 11:02 AM   #35
xpickup
xpickup's Avatar
Re: 47 Step van
youngrodder, Thank you. Yes, I can not wait to see it on also. It will fill in that big hole back there.
skymangs, It is totally different. Which really makes it cool.
69CST-V, Thank you. Your not late, I have a bunch more to do!
Shannon
Old 12-18-2013, 11:11 AM   #36
oldman3
oldman3's Avatar
Re: 47 Step van
Hey Shannon, quess I might as well tag along to see some more outstanding work (never get tired of watching your work)...Jim
oldman3 is offline   Reply With Quote
Old 12-18-2013, 11:03 PM   #37
xpickup
xpickup's Avatar
Re: 47 Step van
oldman3, Thank you very much, glad you like my work. I always love to read the comments and is why I post my stuff. And maybe someone might learn how I did it and be able to use it on there build.
Shannon
Old 12-20-2013, 10:32 PM   #38
xpickup
xpickup's Avatar
Re: 47 Step van
We'll I had off from work today so I worked on the step van today. I started off TIG welding in the recess in the roll pan. Then ground and sanded it up. Next was to fit it up. I then finished up the exhaust. I had to do over the axle and out the back. I still have to do the hangers in the rear. The parts store only had 2 when I was there, go figure. I also cut some spacers for the frame where it go higher for over the rear. Then make the mount for the brake booster and the pedal assembly. I used 1/4 inch plate. It is actually going above the frame because of how you set in the truck. I will share a little trick. I used as slitter wheel and only cut about 3/4 of the way and then bent it till I was happy with it. Then I cut a gusset and tacked it in. Then welded the gusset so it would not change and welded where I did not cut through. Sure beat having to deal with a bunch of pieces.
Shannon
Old 12-20-2013, 10:39 PM   #39
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-20-2013, 10:45 PM   #40
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-20-2013, 10:59 PM   #41
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-20-2013, 11:03 PM   #42
xpickup
xpickup's Avatar
Re: 47 Step van
Finally after 5 tries to upload the last 3 picture they are finally on. The I pad about took to the air. It was so much easier till they changed things. Does anybody else have problems uploading pictures. You sure can not do 5 pictures I figured out!
Shannon
Old 12-21-2013, 12:26 AM   #43
oldman3
oldman3's Avatar
Re: 47 Step van
Shannon, back of truck looks great with the tips showing. Exhaust looks super, and you did this outside, on jack stands, in the snow (holy sh!t). I have had trouble with pics sometimes, I think alot depends on size of pic, time you doing it, etc...Jim
Old 12-21-2013, 10:37 AM   #44
Bubba54
Re: 47 Step van
Shannon, trucks looking really nice; fab work is spot on as usual. I think its a Really good idea to repurpose the old iron for modern business, should really grab people’s attention.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 12-21-2013, 12:06 PM   #45
99 to Life
99 to Life's Avatar
Re: 47 Step van
nice work, be cool to incorporate those rivets into the piece.
Old 12-22-2013, 12:32 AM   #46
skymangs
skymangs's Avatar
Re: 47 Step van
Shannon. Love watching your builds come together. One day when I grow up, I hope my fab can be as top notch as yours. Truly an artist brother.
Old 12-22-2013, 06:34 PM   #47
48 GMC BURB
48 GMC BURB's Avatar
Re: 47 Step van
Shannon
As usual your work is Spot on !! LOL...Just make sure you spend sum time with the wife & kids this Christmas !! I don't want them to throw coal at me when I stop up!!
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 12-23-2013, 10:01 PM   #48
xpickup
xpickup's Avatar
Re: 47 Step van
oldman3, thank you. Yes some of the working conditions have been fun. Not! It is too big to fit in the garage plus Kens 51 is still in there. I like the tips, I am going to turn up some inserts for them so it is not just the pipe. The inserts will be aluminum too.
Bubba54, thank you, I too think it is neat to use it for the business. I think the people will remember the name when they see the truck because of how different it is.
99 to life, thank you. I will be using that style of rivets on the roll pan and a few other places on the outside so it blends it with the old. I just have not bought them yet.
Skymangs, thank you, I am watching your builds on here and FB.
48 GMC BURB, thank you and glad you are pleased. Yes rolling right along.
I now have the pedal assembly in, I have one more bracket to make for back on the master cyclinder. I then started to fit the front floors and dog box. I ended having to make new drivers side floor board because someone did some trimming and now they do not fit. So I made some of my paneled floor boards, just out of aluminum this time. It was fun with all the angles. I will rivet them like the factory ones were. Out of aluminum so I have to buy some by the end of the week.
Shannon
Old 12-23-2013, 10:03 PM   #49
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-23-2013, 10:11 PM   #50
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
