Old 12-19-2013, 02:02 AM   #11
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Ultra Family and Hauler Mobile
Was the pitman arm used in the process of removing the seals or did you just kick it around on the floor for good measure? I have never used the fancy seal drivers to install inner axle seals. If I have to use a hammer, I use a long piece of tube, even used a metal broom handle against a seal driver. I have had good luck removing them with a prybar. I never liked how low stock 4x4 excursions sat... now I know why. I also thought Dana used crush sleeves for 35s and smaller... but aren't the 4.30s really a Ford specific application? Gotta make mommas truck drive nice, so I'm glad to see its getting all the maintenance detail you are putting into it! Keep it up!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
