12-17-2003, 04:12 PM | #1 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
rusty @#$%&* gas tank
Ok, I guess my beater sat around for awhile or something...there is a ton of rust in the tank.
I get the luxury of changing fuel filters every couple of days...or if I drive across town (about 50 miles) I get to empty the filter before I finish the trip.... I can look in the neck of the tank and see rust on the sides ... I swear it looks like a bunch of barnacles on a pier. I am sick of wearing this eu de unleaded cologne. is there something I can do to break all this crap up? keep changing filters from here to eternity? or bite the bullet and change the tank? I have one in my 71 that is not rusty and will not be used in the new cab. How daunting of a task is that anyway? |
12-17-2003, 04:16 PM | #2 |
Spare yourself any more problems. Pull the tank, have it boiled out, then use one of the Eastwood tank sealing kits. Second option, probably the quickest, find a clean used tank and put it in.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
12-17-2003, 04:16 PM | #3 |
Robert Olson Transport
either tak the tank or the whole truck to the radiator shop in town and ask them to boil it out that will get rid of the problem it will also show any pinhole leaks you may have or will get they can usually solder it up or of its too far gone then youll have to find a new tank
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-17-2003, 04:18 PM | #4 |
I second what ljbear said, use the one off your 71, it is really easy to swap it out, just pull your seat and take your time take everything off it.
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
12-17-2003, 04:18 PM | #5 |
Resident Curmudgeon
To swap tank 2 - 3 hours. I would invest in a new rubber tank filler grommet if I were you. That way you can cut out the old one making the process of removal much easier.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
12-17-2003, 04:32 PM | #6 |
Alright, I can replace the tank.
I noticed there are 2 different grommets. 67-70 and then 71-72 I will be putting a 71 tank in a 70 truck. Should I get the 71 or the 70 grommet? and will the tanks bolt up the same? |
12-17-2003, 04:35 PM | #7 |
Resident Curmudgeon
Tanks bolt in the same. get the grommet to match year of tank. The only other thing to note is that the 71 tank will have a provision for a vent tube that runs up between the pass side cab roof skins. Just plug them.
12-17-2003, 04:36 PM | #8 | |
Resident Curmudgeon
12-17-2003, 04:43 PM | #9 |
Hot Rods For Life
Hey now would be a good time to relocate your tank and get a Blazer Tank!
12-17-2003, 04:56 PM | #10 | |
MOVE OVER
No matter where you are..... There you are... Buckaroo Banzi |
12-17-2003, 04:56 PM | #11 |
it was never a lack of skill involved with the tank swap.... it was lack of motivation
I noticed those vents the other day when I was contemplating this. and I'm reserving the blazer tank setup for the 71 this is just my beater. |
12-17-2003, 04:56 PM | #12 |
thanks to all for the motivation
12-17-2003, 05:03 PM | #13 |
Failure is NOT an option!
I pulled my tank and swapped sending units in about an hour so it's pretty east.Good Luck.The most aggravating part was getting the filler neck to come through the cab without tearing the paint or seal all to hell,then I just said hell with it and jerked it through!!!
House payment or truck parts?????.........why does life have to be so complicated? 1969 Chevy Shortbed Fleetside 1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto) 1990 Ni$$an hardbody( daily beater that has been really beaten!) 1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me) |
12-17-2003, 05:06 PM | #14 |
jump to it is a simple swap out, and will probaly allow more than 50 mile trips on a filter. you may consider blowing out the lines to the pump and replacing the pump. lots of trash has gone through it obviously.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
12-17-2003, 05:56 PM | #15 |
one more question
If I go ahead and swap the tank, can I install the grommet later?
I have a call in to one of the board vendors, I just don't know if I can get the grommet by the weekend. I would hate to wait because this weekend is the only chance til the new year for me to get this done. Thanks again for the advice |
12-17-2003, 06:47 PM | #16 |
its all about the +6 inches
If you can put it off a little longer, you should go ahead and have your replacement tank cleaned and re-sealed. If it donesn't have any rust or leaks now, chances are it will some time in the near future. (It IS 33 years old)
I have used the POR15 tank kit and recomend it. The filler necks commonly leak where they are soldered to the tank. |
12-17-2003, 07:10 PM | #17 |
Watch out for your cornhole !
You can get a grommet at GM dealer. They're better than aftermarket anyway. They are more supple and much easier to install.
12-17-2003, 07:32 PM | #18 |
tx firefighter you are correct. 8.60 plus uncle sam. and there is one in town and my name is on it as we speak, pick it up in the am.
12-17-2003, 07:43 PM | #19 |
Hey man, I've been there....
I got the pleasure of re-painting the whole side of my cab on my 69 truck because of a ___________ aftermarket filler neck grommet. Those sum*****es are made out of concrete and they do not pop into place properly.
A week's worth of repainting and a new soft GM grommet and I was done. I have strong feelings about cheap aftermarket rubbers (cough****from LMC****cough). Lifetime warranty don't help much in that case.
