Old 11-18-2013, 06:54 PM   #1876
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Ole Driftbeam made it into two calenders!
September (click preview)
October (click preview)
I know what will be in my stocking this year (no affiliation to publisher)
Frizzle Fry is offline   Reply With Quote
Old 11-19-2013, 07:51 PM   #1877
mcbassin
Still Learning
mcbassin's Avatar
Very nice! Congrats!
good picture too.
Old 11-21-2013, 10:55 AM   #1878
Frizzle Fry
Thanks Mike. Here a bigger one. Should be able to read the description. But you guys already know that stuff and much much more
Old 12-06-2013, 03:40 PM   #1879
socorob
This is a great build. Makes me miss my Sunbeam.
socorob is offline   Reply With Quote
Old 12-09-2013, 10:59 AM   #1880
Frizzle Fry
Thanks socorob.
Shop got a little love. More left to do, but it's warmer and better lit now:
And the Prodigal Son returns!
Old 12-09-2013, 12:54 PM   #1881
ERASER5
ERASER5's Avatar
Time to find the fatted cat ... er.. calf. Yea, that's what I ment.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-09-2013, 02:08 PM   #1882
Frizzle Fry
Not sure if I mentioned - the floor, eng bay, trunk, and entire underside are still bare since I have a few loose ends to clean up in those areas. I'll be spraying the SPI epoxy myself and hitting the underside and wheel wells with Raptorliner within the SPI respray window.
Old 12-09-2013, 02:28 PM   #1883
mcbassin
Still Learning
mcbassin's Avatar
Congrats on getter her back home. Looking forward to the next phase. You are boing to reach the 500K hit milestone soon. You might be the only builder on here with those numbers on 2 separate builds.
Old 12-10-2013, 05:07 AM   #1884
Frizzle Fry
Well, I guess that's what happens when you start something and don't finish it for years ...and years
Old 12-10-2013, 06:28 AM   #1885
You done yet?
Old 12-20-2013, 02:02 AM   #1886
dammitmitchell
the pollock
dammitmitchell's Avatar
where's the paint! jeesh sure taking your time!. haha
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-20-2013, 02:36 AM   #1887
Frizzle Fry
Workin a graveyard shift this month and hitting the gym in the mornings after work - doesn't leave much left for wrenchin. Last weekend was full of xmas parties (thus the need for exercise ). Headed out there now!
Old 12-29-2013, 11:30 PM   #1888
Frizzle Fry
My welder is loaned out to a friend whose building a chump-car. Been hammer/doly'in a few little dings here and there. Nothing really pic-worthy. Working night shift makes the opportunity for making noise a bit limited. That ends in two days
On of those nights when I couldn't make too much noise I dove into the engine disassembly. Got it pretty well torn down (external bolt-ons only) and cleaned. Researching finishing options for the cast aluminum now.
Thinking I might have to do something like this to my intake - shaved (not black though)
Old 12-31-2013, 01:16 AM   #1889
dammitmitchell
the pollock
gettin carried away, what's wrong with a glossy powder coat?
Army vet 02-08
Old 12-31-2013, 02:03 AM   #1890
Frizzle Fry
Carried away = the theme of this build! I can't have all those unused vac ports wearin rubber caps taunting me every time I open the hood. They gotta go! As far as finish, I'm leaning toward painting with Duplicolor cast coat aluminum and Eastwood diamond clear satin.
Here's a bike engine done with that combo:
Old 01-02-2014, 01:02 PM   #1891
theastronaut
theastronaut's Avatar
Have you thought about having a single stage urethane mixed to match the aluminum color you want, and adding in a little bit of flattener to knock it down from a full gloss? That way it would be a hardened paint and would be way more durable. I did a charcoal colored urethane with flattener on the block in my '64 VW (magnesium) and it's held up very well to the heat and oil over the last 2.5 years, still looks as good as the day I sprayed it. I did spray epoxy first for better adhesion.
theastronaut is offline   Reply With Quote
Old 01-05-2014, 08:42 AM   #1892
Frizzle Fry
That does sound ideal. I had already picked up the cast-coat aluminum some time ago. Just received the Eastwood Diamond clear yesterday. I've read nothing but good things about it, but I do realize that any paint is only as good as its foundation. I'll execute to plan this time and see how it goes.
Old 01-07-2014, 07:36 AM   #1893
Frizzle Fry
Got a new toy in the shop. A stud welder.
I know there have been a lot of comments about how perfect the body was, but the blasting did reveal a few flaws here and there. Nothing major (unlike the front/right corner I already replaced).
People have asked me why I didn't get the body work sorted before blasting/primer. The answer is two fold:
  1. The car was taken for blasting at that time to continue progress on the project while I was out of the country
  2. You don't know the condition of the body 100% until it's stripped
So I'm working small areas at a time and will re-apply epoxy once I get them as straight as I can. Here are few pics of the little bit I've done so far. These are only dents with no back-side access. A few others I've already worked with the hammers/dollies:
All these dents and holes were buried in bondo! Getting to work with the stud welder:
Also started prep'ing the engine for paint:
Old 01-07-2014, 08:13 AM   #1894
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
This build has come a long way. Everything looks great. I like the looks of that Duplicolor cast coat aluminum and Eastwood diamond clear satin. I wonder how that would look on a bigblock !
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-07-2014, 09:26 AM   #1895
Frizzle Fry
I bet it would look awesome! A good clear should make it easier to keep clean too.
Old 01-07-2014, 09:51 AM   #1896
bbrally
It's hard to believe I've been following this as a part of my morning coffee ritual for almost five years.
It's awesome to see her so close to the finish line, but I'm going to miss seeing what you've done to her next when she's finally on the road for good.
I may have missed it, but I didn't see any posting of remounting the shift housing back onto the trannsmission. Do you have any info/pics on how you accomplished that?
Keep up the excellent work, you help to motivate me in my substantially less enthusiatic build.
bbrally is offline   Reply With Quote
Old 01-07-2014, 12:13 PM   #1897
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the Beam. I have one of those stud pullers in my shop. (borrowed from a good friend). They are a life saver on body repair. A must have! congrats
Old 01-07-2014, 02:45 PM   #1898
sparkydog
sparkydog's Avatar
There's 1,500 of the 4XX,XXX views!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 01-08-2014, 12:21 AM   #1899
Frizzle Fry
Wow, and first post! Thanks for stickin with it. I know progress gets pretty slow at times.
I may have missed it, but I didn't see any posting of remounting the shift housing back onto the transmission. Do you have any info/pics on how you accomplished that?
I had it welded by a guy set-up with mig and tig for al. After he left I noticed a slight bind on the shift rod, so I tapped (hit it pretty hard) laterally with a rubber mallet and it partially fractured the weld(s). The bind improved and the shifter housing was still secure, but it was never completed to the point of my satisfaction, and is on the to-do list. I now have the ability to weld aluminum myself, so I'll give it a shot soon. Good memory by the way
Yeh, I'm digin it already
Hah, and probably 66% of them were met with disappointment
Old 01-10-2014, 11:26 AM   #1900
Low Elco
Love my Stud Gun. Great for making heat shrinks if you're not confident in your torch abilities (like me). This thread never disappoints. Whatever gets it on the road and the Tahoe up to bat! Damn, I love that truck.
Low Elco is offline   Reply With Quote
