Old 12-22-2013, 11:34 PM   #1
K10Scottsdale78
K10Scottsdale78's Avatar
Starter for 400 SBC
I went to use my truck today since my daily driver was in an accident (I rear ended an SUV on the highway in holiday shopper traffic when studded tires lost traction from braking hard in the rain and slid for 3-4 seconds before impact).
It started fine at first, but engine shut off a couple minutes after starting (cold start 40 degrees with no choke). I went to start it again, and nothing happened when I turned the key.
We tried jumping it and tapping the starter with a rubber mallet, and still wouldn't turn over. My best guess is that the starter is shot. Where can I find a budget-minded replacement starter for a 400 small block? Can't spend a lot since all my money is going into fixing my daily driver, paying "following too close" ticket, insurance increase etc., (not to mention I wasnt expecting to have to replace my starter after my accident) and now need to make my truck my DD for a while since my car is in pieces in my garage.
-1978 K10 Scottsdale LWB
400 SBC 4 spd muncie SM465 ("heavy chevy")
-2002 Toyota Celica GT
5spd (gas saving daily driver)
-1969 Pontiac Firebird (post-college project car)
K10Scottsdale78 is offline   Reply With Quote
Old 12-23-2013, 12:21 AM   #2
Zane M
Re: Starter for 400 SBC
Any auto parts store will have a budget line of reman starters. Don't know how long they last, but they will get you by for a while.
If you are really strapped, go to the local pick and pull and roll the dice on a starter you pull.
Zane M is offline   Reply With Quote
Old 12-23-2013, 01:09 AM   #3
83GMCK2500
Double-check cable ends at battery and starter and wherever your primary ground terminates. Find it hard to believe starter would die after working once, sounds like a random electrical gremlin from sitting. Does it click or do anything?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-23-2013, 01:10 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Cheap part store starters can fall apart easy. I lost half mine on the hwy when driving and was strapped for cash at the time myself. Igot it replaced for free and it happened again. In the driveway (luckily). I went and got another and this time I lock rite all the screws and bolts holding it together.
If you do get another just check it over real good. Price shouldn't be to bad with a core
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-23-2013, 01:42 AM   #5
Paul83
Paul83's Avatar
This is what I would do. Always check electrical first. Especially since it died. Clean all the ends and battery posts, hook battery up to charger. See what happens.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
Old 12-23-2013, 11:33 AM   #6
K10Scottsdale78
We did try checking the connections to the battery, and my friend listened to the starter when i was trying to get it going, he did hear the starter click
Old 12-23-2013, 11:37 AM   #7
K10Scottsdale78
Yeah my dad thinks it could be a bad connection from sitting and all the snowmelt we have been having. Hopefully thats all it is, would save me some money that I wasn't planning on having to spend after my accident on friday
Old 12-23-2013, 05:20 PM   #8
slugish
Slugish
iM ure you already know this but if you have headers , the heat from them will fry a stock or parts store starter pretty quick . hopefully you fixed already
slugish is offline   Reply With Quote
Old 12-24-2013, 04:55 PM   #9
superwade57
If its clicking try replacing just the solenoid?
superwade57 is offline   Reply With Quote
Old 12-24-2013, 10:45 PM   #10
donut
donut's Avatar
Have you thought to just take the old starter to Auto Zone or equivalent and have it tested? While it's down you can check all your electrical ends and make sure they're clean and solid.
My last starter failure was actually a broken connector on a wire to the solenoid.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-11-2014, 05:19 PM   #11
K10Scottsdale78
I finally got around to replacing the solenoid today. Still wont crank.
The only way it starts is by hot wiring it by using the old screw driver to the solenoid trick. If I turn the key, nothing happens.
Could it be a bad wire somewhere or possibly? The wires to the solenoid looked ok, and there is a heat shield to protect them from the headers
