Old 12-09-2013, 10:33 PM   #1
hayhauler71
hayhauler71's Avatar
Need help steering shaft repair
I am redoing my steering column and noticed that the rubber boot on the steering shaft [the rubber boot that holds grease in the slip joint] has failed and the slip joint is worn. I want to know if I should cut the shaft and replace the the slip joint with a 3/4 36 spline x 3/4 dd coupler or does a universal joint need to be installed. I will be drilling the shear pins out of the shaft so i will have a slip point. Any pics of modified shafts would be great. Thanks
1971 c 10
manual steering
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 12-10-2013, 12:00 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Need help steering shaft repair
1971 c 10
manual steering
If I were you I would just find a good stock replacement one...
LockDoc
Leon
Old 12-16-2013, 11:58 AM   #3
hayhauler71
ttt
Fuzzy
Old 12-23-2013, 04:56 PM   #4
hayhauler71
Well some time has gone by and I have removed and body worked the shifter bowl to make it smooth and got the steering column stripped and painted and it is looking good. I did pick up a u joint that is a direct fit and looks good to. Next I sent the slip shaft with my buddy to mill it dd all the way so I can cut it to the proper length. Here is a few pics
Fuzzy
Old 12-23-2013, 05:15 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks nice, should work real nice
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-23-2013, 05:19 PM   #6
hayhauler71
Thanks Dale the old joint had lots of play and I did not like the grease running out of the boot on my fenderwells
Fuzzy
Old 12-23-2013, 05:28 PM   #7
Ol Blue K20
If you replace the rag joint with a new one the steering should feel nice and tight. Some people replace the rag with a u joint as well but in my opinion that lets to much vibration to be felt at the steering wheel.
Dale
Old 05-11-2014, 10:17 PM   #8
jammer3096
How do people hook up the second u joint instead of rag joint? Does it take out more play than a new rag joint?
jammer3096 is offline   Reply With Quote
Old 05-11-2014, 11:05 PM   #9
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Here's what I use on my trucks, early to mid 90s Jeep Cherokee steering shafts, it's almost a bolt in. You will have to heat and collapse the shaft just a little and on the columns shaft you will need to grind or file a very small notch to clear the Jeeps pinch bolt. The Jeeps shaft has a built in vibration damper and I've found this setup really helps firm up the Chevys steering. Practically a bolt in for around 30 bucks from a salvage yard.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-11-2014, 11:06 PM   #10
BLAZERMAN
BLAZERMAN's Avatar
Another
Old 05-11-2014, 11:07 PM   #11
BLAZERMAN
BLAZERMAN's Avatar
One more
Old 05-12-2014, 11:10 AM   #12
airdale94
airdale94's Avatar
Wow! Great information! Thanks!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 05-26-2014, 11:43 PM   #13
jammer3096
Does the universal joint slide all the way on column end until bottoms out or until flush with inside hole? Hopefully that makes sense. Lol
Old 02-20-2016, 11:40 AM   #14
Leadbelly
Digging up an old bone but very appropriate to my question. Blazerman's photos give reference. Jeep splines are 3/4 -36? and the other is 3/4 DD? Like Borgeson unit but price is a bit steep.
Leadbelly
Leadbelly is offline   Reply With Quote
Old 02-20-2016, 12:18 PM   #15
'68 Newtricks
'68 Newtricks's Avatar
I believe to. I have an XJ shaft on my Blazer and C10. Around here, they are about $6 from the yards. Most of the time the rubber at the top is worn and sloppy, so I weld it. Amazon sells new shafts for $99 last I saw. They are on most square body Cherokees, not the Grand Cherokee. 80s- early 90s
I've probably used or sold 20 of them.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 04-20-2016, 07:13 PM   #16
thunderchicken
Just wanted to say thanks for the info. This is exactly what I was looking for. Best 10$ spent so far.
thunderchicken is offline   Reply With Quote
Old 09-24-2017, 02:43 PM   #17
BlueBullet
BlueBullet's Avatar
Does the Jeep steering shaft mod only work for manual steering boxes
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 09-24-2017, 07:23 PM   #18
Leadbelly
My guess, top yeah, double "D" and 3/4". As far as steering box do not know the spline count so no idea.
Leadbelly
Old 09-24-2017, 07:29 PM   #19
BlueBullet
BlueBullet's Avatar
I got the steering shaft but it does not work for a 72 4x4 with power steering. I thought this worked for all 67-72. If so wondering what I might be missing.
1967 Pontiac GTO
Old 09-24-2017, 11:09 PM   #20
crakarjax
crakarjax's Avatar
How many splines on your power steering box?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-25-2017, 10:25 PM   #21
BlueBullet
BlueBullet's Avatar
32 splines
1967 Pontiac GTO
Old 09-26-2017, 12:02 PM   #22
crakarjax
crakarjax's Avatar
32 splines
From the info above, the jeep shaft looks to be 36 spline so I'm thinking it won't work.
Old 09-26-2017, 12:19 PM   #23
Leadbelly
I found it quicker, much easier, and guaranteed to work going to CCP. I am switching to Borgsen just because I am not a fan of chrome polishing on the joints for my truck plan. Black are easily overlooked. Here is a link to my swap, from ordering parts bolting on new parts.
https://www.flickr.com/photos/dodson...57662779313234
Sorry do not know if or how to post build pics.
Leadbelly
