Old 12-23-2013, 08:30 PM   #1
tinydb84
tinydb84's Avatar
Re: 1970 c10 LSX 427 twin turbo setup
Dyno??
David
Instagram: myfabguy
Old 12-24-2013, 02:16 PM   #2
rgonza
Originally Posted by tinydb84 View Post
Dyno??
1378 rwhp @6890 Rpm 19 pound of boost
rgonza is offline   Reply With Quote
Old 12-26-2013, 02:48 PM   #3
69trk
69trk's Avatar
where did you get the ac bracket? I'm doing a turbo build also... love the truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-26-2013, 02:50 PM   #4
69trk
69trk's Avatar
Are you using truck exhaust manifolds?
1.58- 60'
11.37- 1/4 @115.81
Old 12-26-2013, 05:24 PM   #5
rgonza
Hi, Not is a custom made, the truck manifold work good , but because of my setup need ones can flow more highter, so it are very easy to do we build that from black steel elbows and reducer from a boiler supplier.
Old 12-26-2013, 05:35 PM   #6
rgonza
Here's the pics
Old 12-26-2013, 05:44 PM   #7
rgonza
Installing the center console.
Old 12-26-2013, 05:51 PM   #8
69trk
69trk's Avatar
That is awsome..... I just ordered the ac bracket.... thanks
Are you using the holley dominator efi or the hp? Or a different ecm?
1.58- 60'
11.37- 1/4 @115.81
Old 12-26-2013, 05:58 PM   #9
rgonza
i'm using Holley Dominator EFI Because i'm using to control the 4L85e Transmission ,the paddle shifter and drive by wire throtle body, with the holley HP you can not is just to control fuel and timing the engine not the transmission unless you use manual or not computer controlled transmission.
Old 12-26-2013, 05:21 PM   #10
rgonza
Hi, The bracket come from lsbracket.com this is a high mount bracket kit. the alternator and power steering come from 2002 chevy silverado 5.3Lt.
