Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-27-2013, 02:04 AM   #1
JPBrecheisen
1960-66 Big Truck Rubber Floor Mat
I thought I might post this just in case anybody else wanted to have some info.
I recently started cleaning up my 1960 C60 Viking. It didn't have a floor mat in it, and reproductions are not available for the big trucks. The fitment can be a bit of an issue since the transmission access panel (tunnel, hump, whatever you call it) is fairly flat with minimal rise.
I did some research and found one that I thought might fit pretty well for my truck. Its not "exact", but I think it turned out pretty nice for an item that is intended to be used in a different truck.
I used the floor mat that is supposed to fit a 67-72 model year truck with the small hump. I noticed those trucks had a really low transmission tunnel cover and I know the cab dimensions as far as floor pans etc. were pretty close. It took a little tugging and stretching hear and there, but I am happy with the results.
I ordered the mat from Classic Parts Part No. 39-033.
The shop was dark, but here are the photos of the almost completed installation.
Jonathon
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 11-27-2013, 08:53 AM   #2
Katrina/10
Katrina/10's Avatar
Re: 1960-66 Big Truck Rubber Floor Mat
That fits pretty well!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-27-2013, 10:51 AM   #3
68panelman
68panelman's Avatar
Not bad at all. Good job.
68panelman is offline   Reply With Quote
Old 11-27-2013, 07:53 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looks good!
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 11-27-2013, 11:42 PM   #5
JPBrecheisen
Thanks Everybody.
I am happy with the way it turned out.
Old 12-23-2013, 02:36 PM   #6
Carl Spangler
Carl Spangler's Avatar
What did you think of the quality of the 'rubber' material?
thanks
JohnG
Carl Spangler is offline   Reply With Quote
Old 12-23-2013, 02:58 PM   #7
68panelman
68panelman's Avatar
Yours looks like the same pattern as oem. There's a lot of threads about the quality of the after market material failing within a years time. I managed to buy soft pliable originals from the parts for sale on this forum. Mike.
Old 12-23-2013, 11:50 PM   #8
JPBrecheisen
thanks
JohnG
Well, "good" is subject to personal opinion, but I am happy with the quality. I used one from classic parts before in my 72 K25. That particular mat was purchased around 2004 and it has been just fine. It does have a small amount of very fine dry rot splitting in it in certain areas if you look really close, but no tears or cracks. The fit on that one was really good too. I had good luck with that mat, so that's why I went with classic parts on this one.
I think its a good quality for what I paid for it. I plan on buying one from them for my 62 when I get to that point.
I hope that helps.
Jonathon
Old 12-24-2013, 12:03 AM   #9
Carl Spangler
I hope that helps.
Jonathon
Thanks for the detailed response!
cheers
JohnG
Old 12-24-2013, 07:46 AM   #10
3v0
Thanks Everybody.
And you should be. Looks great.
3v0 is offline   Reply With Quote
