12-23-2013, 12:45 AM | #1 |
laying low
LS swaps and gauges
With so many of you doing the full LS engine and tranny swaps what are you doing for gauges and speedo? I know a few of you have used GPS but what about the stock gauges, lights, speedo ect?
What do you have to use to make the stock ones work?
12-23-2013, 01:08 AM | #2 |
Truck junkie
Re: LS swaps and gauges
To use the stock temp and oil guages you need only to plumb in the original sending units. The temp guage reads a little higher because the LS thermostats are usually 195 and the motors seem torun pretty close to 200-210 if I recall correctly but the speedometer is a different story. The speed sensors serve a few purposes so they need to be plugged into the ecu no matter what you do. We mainly use digital instruments in our LS builds so I'm not sure what's available for using your existing speedometer.
12-23-2013, 08:42 AM | #3 |
I believe there is an adapter of some sort to turn the VSS pulse into a spinning motion for the speedometer cable...can't remember where it was at but I think it was fairly expensive.
71 K20 64 GMC mud truck |
12-23-2013, 08:59 AM | #4 |
There is a thread in the LS swap area about converting your OE speedo to electronic using an S-10 speedometer
12-23-2013, 10:19 AM | #5 |
Abbot Cable-X. They're ~350 new, used ones come along once in a while. I have one I would sell for $250 that is practically new.
12-24-2013, 12:15 AM | #6 |
Hi Boog, I will be selling my shiftworks brand conversion from my 4l65e trans. This allows the stock speedo cable to be used and puts a vss signal out to the pcm. This is all handled in a converted extension housing. I'm converting to electronic speedo. Also I used the stock engine temp sender threaded into the face of the truck Ls water pump. I installed a 4 ohm resistor 1/2 watt inline to the sender so the 200 degree ls motor would show 1/2 gauge in the stock gauge cluster. Good luck Brian F.
12-24-2013, 10:52 PM | #7 |
laying low
I knew of the cable x converter. I wondered if there was now something else you guys were using. I have not heard of the shiftworks converter.
I know some of you go with aftermarket digital instruments but I like the OE gauges in my trucks. I'm not about to dive into an LS swap just now, only fact finding.
12-24-2013, 11:25 PM | #8 |
Dakota Digital VHX!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-25-2013, 12:14 AM | #9 |
laying low
Yes Rob. It is pretty alright.
12-25-2013, 05:32 PM | #10 | |
This is a thread I just found not to long ago. How to build a stock looking electronic speedo. |
12-26-2013, 02:52 PM | #11 |
I bought a set of Classic Instruments gauges, I like the fact that they look pretty close to stock with just a little bit of a modern touch to them. I haven't received them yet, and I'm just barely starting my LS swap (haven't found the motor/trans yet but still collecting parts) but I'll post up about them once we get to that point.
http://www.classictrucks.com/tech/10...972_chevy_gmc/ |
