Old 12-23-2013, 10:46 PM   #1
of13swc
part name help
OK I am sure stupid question what is the name of the part that is inside the engine bay that the hoses go to passenger side that looks like is used for defrost?
of13swc is offline   Reply With Quote
Old 12-23-2013, 10:49 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: part name help
I think you mean the "Heater Box" or "heater Core"?
Old 12-23-2013, 11:36 PM   #3
donthekawguy
donthekawguy's Avatar
Re: part name help
It the heater core inside the heater box. Someone will post a pic soon I'm sure.
66 shorty
donthekawguy is offline   Reply With Quote
Old 12-24-2013, 09:33 AM   #4
of13swc
Re: part name help
Yep that's it. Thank you and also for the link on how to put one back together.
Old 12-24-2013, 09:45 AM   #5
of13swc
Re: part name help
Old 12-24-2013, 03:04 PM   #6
of13swc
Re: part name help
OK so next question is where can I get one?
Old 12-24-2013, 03:15 PM   #7
of13swc
Re: part name help
Or the better question is I have the piece inside the cab do not have the box inside the engine bay. I am trying to reconnect everything. Do I need the heater box or is there another way to hook everything back up?
Old 12-24-2013, 05:11 PM   #8
hotrodder
Re: part name help
You have to have the box itself, because if you want heat you have to have the heater core. one other solution is to buy a heat/air unit that either under or in dash but that is rather costly. I'm sure you can pick up the parts for the outside of the firewall from someone here on the site, and buy a new heater core, from a aftermarket dealer, or maybe even napa.
hotrodder is offline   Reply With Quote
Old 12-24-2013, 05:26 PM   #9
of13swc
Re: part name help
OK here is what I have. Just not sure what or if k need anything else to make it work. Anybody know what I need and can tell me what to do to get it to work?
Old 12-24-2013, 08:45 PM   #10
jtrichard
Re: part name help
you do NOT have the deluxe heater as pictured above i am not familiar with the standard heater so i cant tell you just what you have but from the pic it has a lever that switches it from heat to defrost that is manually operated .....what year we working with here? looks like it may have had ac at one time in its life with the other holes i see ....ok i just did some hunting and it looks like that heater is out of a 55 to 59 pickup
jtrichard is offline   Reply With Quote
Old 12-24-2013, 10:01 PM   #11
of13swc
Re: part name help
It's a 1965. It did have a/c but was put together correctly so I took it off.
Old 12-24-2013, 10:56 PM   #12
of13swc
Re: part name help
one cable running to the hose that looks like it should connect the pipes sticking out of the fire wall. that's about it. the truck had an aftermarket a/c on it but was ugly and seemed like it was not put together correctly so I took it off I am now just trying to get what I posted back together.
Old 12-25-2013, 02:21 PM   #13
61K10
61K10's Avatar
Re: part name help
that is not a stock heater for a 60-66. you need hose's from the water pump and manifold to the heater nipples.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-25-2013, 04:24 PM   #14
johnny's classics
johnny's classics's Avatar
Re: part name help
of13swc, I have a heater core box that I took off my truck during reconstruction that I am not using. If you need it, drop me a p.m.
johnny's classics is offline   Reply With Quote
Old 12-25-2013, 06:32 PM   #15
of13swc
Re: part name help
I have those hoses. Is that all I need to do is hook up those hoses?
Old 12-25-2013, 06:33 PM   #16
of13swc
Re: part name help
I am not sure if I need one I am so confused on what I need or do not need.
Old 12-25-2013, 09:12 PM   #17
of13swc
Re: part name help
Here are the hoses. Any suggestions. If all I have to do is hook up these hoses that would be great.
Old 12-25-2013, 09:21 PM   #18
of13swc
Re: part name help
So how will that work with the unit i have that is inside the cab.
QUOTE=hotrodder;6433438]You have to have the box itself, because if you want heat you have to have the heater core. one other solution is to buy a heat/air unit that either under or in dash but that is rather costly. I'm sure you can pick up the parts for the outside of the firewall from someone here on the site, and buy a new heater core, from a aftermarket dealer, or maybe even napa.[/QUOTE]
Old 12-26-2013, 12:41 AM   #19
jtrichard
Re: part name help
Yes hook up the hoses there should be a fan on the inside im guessing if it is hooked up and working? you could put a valve in the line from the intake man. fitting that you can shut off in the summer..... as i said before the heater you have looks like is out of a 59 chevy pickup
Old 12-26-2013, 01:15 AM   #20
Captainfab
60-66 Nut
Re: part name help
I agree with jtrichard, That is not either of the '60-'66 heaters. It is from another year of truck that someone has installed into your truck. You should be able to just connect your heater hoses to those nipples, and you will have heat and defrost. However it will not work as well and the original deluxe heater. Depending on the climate in your area that may or may not be an issue. The '55-'59 heaters don't do very well in cold climates as we have here in North Idaho. You might be better off to repair the AC/heater that was in your truck and reinstall that, versus what you have in there now.
Old 12-26-2013, 10:14 AM   #21
of13swc
Re: part name help
Thank you all for the help. I wish I had the original heater but I do not. I would love to find the economy heater that was in the 60-63. But on the other hand I am in southern Mississippi so it does not get to cold here and when it does it does not last long. Thank you all for all the help I love this forum everybody is always so helpful for us guys that are not to smart.
Old 12-26-2013, 10:19 AM   #22
of13swc
Re: part name help
jtrichard is this what you are talking about installing?
Old 12-26-2013, 01:23 PM   #23
jtrichard
Re: part name help
Yes ....that will keep the extra heat out of the cab in the summer time
Old 12-26-2013, 05:04 PM   #24
hotrodder
Re: part name help
hook um up and see what you have. never know till you try it. won't hurt anything.
