Old 12-26-2013, 06:58 PM   #6
mud.man.rj
mud.man.rj's Avatar
Re: About to the first oil change since engine rebuild, got a couple questions.
I break an engine in in the first run, so 15 -20 minutes, change oil, put on about 300 kms, change oil then every 3 times a year with low kms on it just to keep the acid level in used oil down, usually ends up being 1,500 kms. I may change it a bit to often but better clean than not and cheap insurance, also use a botle of GM additive on every engine, every oil change. Not much for price if synthetic. usually run 5w30 in colder climate and 10w30 the rest of the year.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
