Old 12-26-2013, 09:45 AM   #76
60-66
60-66's Avatar
Re: Any pics of trucks with spotlights?????
Heres our 1966 GMC ordered new with spot lights.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-26-2013, 11:15 AM   #77
NurseBen
NurseBen's Avatar
NurseBen is offline   Reply With Quote
Old 12-26-2013, 11:33 AM   #78
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
C/10 King, can you take some more pictures of the brackets (in and out), for the through the roof one? My son's truck already has a hole in the middle of his roof that we have plugged with a bolt. He wants to put a spotlight there to fill it. LOL
Thanks!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 12-26-2013, 11:56 AM   #79
NurseBen
NurseBen's Avatar
Old 12-26-2013, 05:33 PM   #80
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by chevy_man5 View Post
C/10 King, can you take some more pictures of the brackets (in and out), for the through the rood one? My son's truck already has a hole in the middle of his roof that we have plugged with a bolt. He wants to put a spotlight there to fill it. LOL
Thanks!!
These are frequently listed on Ebay for dirt cheap, as they are not very popular. Here's a newer example for low cost. I believe this specific example probably has the plastic lamp shell. The only things that appear to be missing are a flat gasket for the outside bracket, and a short piece of fuel tubing for the inside gasket:
http://www.ebay.com/itm/Unity-6-inch...tr#ht_59wt_888
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-26-2013, 11:11 PM   #81
TJ's Chevy
TJ's Chevy's Avatar
Do any of you have any recommendations for a good spot light for my '66? And a good place to get one? Thanks!
Old 12-27-2013, 12:02 AM   #82
C/10 King
C/10 King's Avatar
Thanks!!
Chevy man, here you go.....I hope this helps,........but if it was up to me, I would just weld up the hole.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 12-27-2013, 07:02 AM   #83
clemdaddy
clemdaddy's Avatar
heres a buddies truck. his has the baby spots from unity. they look great with the small round mirrors.
clemdaddy is offline   Reply With Quote
Old 12-27-2013, 02:04 PM   #84
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks Markeb01, and C/10 King.
Welding the hole was my suggestion too, but he is 16. What do I know! LOL
Jason
Old 12-27-2013, 03:04 PM   #85
markeb01
Senior Enthusiast
markeb01's Avatar
My suggestion would be to buy the outside bracket from Unity since they still offer them brand new:
http://shop.unityusa.com/search.asp?keyword=187
This is what the correct 187 bracket looks like:
Note in this template photo the inboard mounting screw is below the body line:
And in this photo with the spotlight removed, the inboard (external) mounting screw hole is again below the body line:
When the correct 187 bracket is used, the inside hole for the shaft enters the cab like this:
For the spotlight, I recommend searching Ebay until you find a New Old Stock Unity “The Beam” with a part number having S6/225A in it:
The “A” indicates the correct shaft length of 12”. The S6 indicates the standard larger 6” lamp head. The smaller version is known as the 5”.
The last one I bought was NOS for $25. Bargains can be found on vintage spotlights, but prices on many are outrageous, as most are rusty, pitted, broken, or have missing pieces. Also the “parking” feature will almost always be worn away to where the lamp head rests on the body of the vehicle. NOS lamps park correctly at any distance from the body panel you prefer. If you decide to buy a 50 year old lamp check the photos very carefully. Many sellers are very clever about taking favorable photos that don’t show the severe pitting on the die cast parts and the chrome lamp shell. The most expensive lamp I ever bought from a popular Ebay seller was almost useless due to pitting and rust. I ended up using the topknot emblem and the black short GM only handle. Just be careful.
The following thread starting at post #12 shows how to modify a “The Beam” version to cosmetically look like a vintage unit. Good luck!
http://67-72chevytrucks.com/vboard/s...d.php?t=403869
Old 12-28-2013, 07:37 PM   #86
clemdaddy
clemdaddy's Avatar
nice mark, definitely worth repeating.
i got a pair of the 5" spots off e-bay and the new installation kits is the way to go. the last time i called (about 1 month ago) the left side were readily available but they only had a few right side. if unity doesn't have them on the shelf it could take several months for the foundry to make more.
Old 12-28-2013, 07:41 PM   #87
TJ's Chevy
TJ's Chevy's Avatar
Thank you very much Mark!! it helps alot! I'll keep my eyes pealed on ebay and see what I can find! Thanks, T.J.
Old 07-02-2014, 11:40 AM   #88
1963c-10
1963c-10's Avatar
Any new additions? Heres one with the spotlight and hood ornamnet
1964 Short bed trailer
Old 07-02-2014, 11:52 AM   #89
1963c-10
1963c-10's Avatar
Clemdaddy.....did you ever get your spotlights installed?
Old 07-02-2014, 12:44 PM   #90
clemdaddy
clemdaddy's Avatar
yeah, did a drivers side one in the utility bed truck i'm working on. also did the 2 baby spots on my buddies light blue 66. seems fairly easy to do, only critical thing is drill angle when punching through the pillar.
still got that smash-hit? very jealous...
Old 07-02-2014, 01:28 PM   #91
1963c-10
1963c-10's Avatar
Very cool. I actually do have it back. Was sold to a local guy and he got rid of the truck and called asking if I wanted to purchase it back. Its a 60-62 model. I can get pics if interested.
Old 07-03-2014, 07:26 AM   #92
clemdaddy
clemdaddy's Avatar
definitely interested. clem@hogeye.com
Old 07-03-2014, 11:01 AM   #93
RatRide
My truck came with dual Unity spots from the 60's. Unity's customer service is awsome!!!! They were able to work with me and only sell me the parts (inner handel gearing) I needed to get them working again. Their design for these spots have change through the years but most of the parts will fit together.
I'll take close-up pics this afternoon.
RatRide is offline   Reply With Quote
Old 07-03-2014, 11:17 AM   #94
1963c-10
1963c-10's Avatar
I had great customer service with Unity as well. Thanks for sharing the pics and great looking truck!!
Old 07-04-2014, 02:27 PM   #95
RatRide
Old 07-04-2014, 02:28 PM   #96
RatRide
Sorry for the upside down pics.
Old 10-11-2014, 03:40 PM   #97
TJ's Chevy
TJ's Chevy's Avatar
Here's mine....
Old 05-12-2015, 02:41 PM   #98
1963c-10
1963c-10's Avatar
Any new additions? I've got my CH-H1 fitted to the 12" shaft now, will get some pics tonight.
pic 2 shows the back of the CH-H1 and pic three shows the correct CH head from the 63 accessories book
Old 05-13-2015, 01:25 PM   #99
1963c-10
1963c-10's Avatar
Heres the pics of the new head on the spotlight on my original shaft
Old 05-13-2015, 05:39 PM   #100
mattbert56
mattbert56's Avatar
Got this one from an old friends dad. He had a box of spotlights. He just gave one to me because he liked my truck hah. Fit perfectly. Only short one he had. Wish I had a second to match on the other side.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
