Old 12-27-2013, 05:14 PM   #1
rgonza
Re: 1970 c10 LSX 427 twin turbo setup
Originally Posted by BR3W CITY View Post
I'm not used to seeing the GV units behind the already-overdrive trannies, do you really get much use out of some of those doubled gears? (without being able to ECM/TCM control the gv unit)
In my case it works very nice on highway and the overdrive + Gv Overdrive + LU cause to drop around 1000 rpm on normal or cruise driving not race, when i switch to manual mode i will able to control the gear vendor through from mastershift paddler shifter control system.
rgonza is offline   Reply With Quote
Old 12-27-2013, 06:11 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Damn, after looking at your build (and watching like 2 hours of Travel Channel), makes me want to go to Puerto Rico lol.
Have you used the Mastershift unit before? I read about it and another similar system, but I've never seen it used, since most of the guys with 6spd auto's will run the GM TuTd shifters. Does it allow for "full" control, or just the GV? (getting tap-shift for all 8 speeds would be epic)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2013, 07:33 PM   #3
rgonza
i Have an Transgo HD2 modified valve bodies so when it put in D4 and switch to auto mode the tranny shift like factories does 4 + manual activation GV Overdrive , But when i ****ch to manual mode i have totally control over the tranny and GEAR VENDOR so there's when the master shift come on, the mastershift you can program it to gear splitting with the GV you will have 8 forward shift from your paddle shifter.
i have an another Modification in this tranny to handle the power from LSX 427 turbo.
1-Hardened Input Shaft
1-Hardened Hub.
1-TCI 2.97 First Gear Set
1-Intermediate Hardened Shaft
1-Alumum Direct clutch Assy.
1-Pump modification
1-34 elements Sprags
1-John Winter 3400 Stall 3 Clutch Lock Up Converter
1-red Alto Frictions
1-kolene friction plates
with this mods the tranny hold over 1400++ with out any issues
Old 12-27-2013, 07:45 PM   #4
rgonza
There's an video clip from mastershift with 4l80e and gear vendor.http://www.youtube.com/watch?v=jeOsodOvabU#t=16
Cheers
Rob
Old 01-02-2014, 06:33 AM   #5
69trk
69trk's Avatar
Looks like you kept the coil packs on the valve covers... Did you just custom make some plug wires andgo around the manifolds?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 01-02-2014, 06:30 PM   #6
rgonza
Yes, it's a custom make cables, because i'm using a Katech coil bracket set the OEM wire are to short to reach the spark plugs there're about 2" more longer than factories does, the wire set are Taylor 10.4 with ls coil ends.
Cheers
Rob
