Old 12-28-2013, 12:51 AM   #1
mgchevyparts
mgchevyparts's Avatar
Re: pros/cons of shock extenders
Originally Posted by N2TRUX View Post
The "pros"are they allow your shock to function properly. The "cons" are you will hate your ride if you dont.
I probably didn't word it right. You can get shorter shocks and not use the extenders so I was wondering if either method is better then the other and why.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 12-28-2013, 12:53 AM   #2
mgchevyparts
I was removing the bump stop brackets, I hate removing factory rivets
So I decided to try my 120v Hobart plasma cutter, worked like a charm. Took about 15-20mins to blow the heads off then pry the bracket loose. Just don't use this method if you want to save the bracket.
