Closed Thread
Old 12-28-2013, 10:22 PM   #8901
ChrisDollins
ChrisDollins's Avatar
Re: What did you do to your truck today?
Me and the little lady took the 66 out for a drive and bike ride. Then downtown to grab a bite to eat. Even though we were doing 10 under on the hwy we still got thumbs up haha. Gotta love driving home with the cool dim green lights on the dash. I love this old truck.
Chris
ChrisDollins is offline
Old 12-29-2013, 11:06 AM   #8902
steveb64
steveb64's Avatar
Finishing up my power steering install. Using a CaptainFab plate and shaft flange. Excellent quality product, thanks Captain.
steveb64 is offline
Old 12-29-2013, 01:26 PM   #8903
LT1 Burb
LT1 Burb's Avatar
Originally Posted by hemifalcon View Post
Repost from my build thread--
Here we go a little deeper--I yanked the rear floor section out tonight. I'm almost done with removing all the undercoating and I think the wheel wells will be the biggest pain as it's really thick and stuck on pretty good. Oh well--just letting the air scaler do it's job. I only ended up breaking two bolts during removal of the rear floor--but decided to finally do it. I will now have to wrestle with the idea of installing a "truck-style" rear floor--or if I'll do the plywood again. If I do the plywood--I'll have to source similar style rubber coating--shouldn't be too difficult. Or--maybe carpet?? Likely rubber.. ORRRRRR--maybe put some nice stainless runners atop the plywood or a raised protective surface?? I dunno--we shall see. Either way-having the floor out makes clean up very easy..
Here are the pics--
someone really hammered the hell out of the inner parts of the wheel houses.. I don't know why--
you can see the two halves of plywood-measured out at 5/8" thick. The rubber top almost seems like it had a layer of asphalt between it and the wood--it does NOT peel off.
rear lip detail.
I used 3/4 marine grade plywood to redo my floor and carpeted over it. If you are running headers I would strongly suggest dynamat on the plywood and then carpet. Also , the floor should be installed when the body is off the frame, I did mine with the body on and it was a PIA.
LT1 Burb is offline
Old 12-29-2013, 02:24 PM   #8904
DexterDog
DexterDog's Avatar
Got bored and cleaned up the engine bay with some new colors.
DexterDog is offline
Old 12-29-2013, 03:46 PM   #8905
mud.man.rj
mud.man.rj's Avatar
Man wish we had -3f, would be awesome instead of -35celcius, poor truck just sits.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 12-29-2013, 07:32 PM   #8906
Hipper
Hipper's Avatar
Doug out the 71GMC out of its resting place for the past couple years. Swapped in stall convert or so I can use stock one in the 65 camper eng trans swap. While there replaced seals and installed b&m deep pan, replaced fuel pump and got it running. Wohoo!!!!!!
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 12-29-2013, 11:33 PM   #8907
joedoh
joedoh's Avatar
brought it home.
sadly this is the last hurrah.
joedoh is offline
Old 12-30-2013, 11:10 PM   #8908
Softpatch
Softpatch's Avatar
Installed my Collector plate on... found a backing plate off another car
Big woof .. well to me it's a big deal because it means
"The Man"
can't ticket me for driving/parking truck on street for non Lic plate
names is not "Jamie" but do still think good girls like bad boys.
I put that frame on temporary it was either this or
"Happiness is being a grandparent"........sp
Softpatch is offline
Old 12-30-2013, 11:31 PM   #8909
wjjeeper
wjjeeper's Avatar
Today I stood in my garage and drank beer with a buddy while he drooled all over the truck. Good times.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline
Old 12-30-2013, 11:33 PM   #8910
Chevy Fleetside
Chevy Fleetside's Avatar
Today I drove it.. yesterday I drove it. Friday I picked up sheetrock and Durarock at Lowes for a job I am doing and tomorrow I am going to drive it. I love this truck.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 12-30-2013, 11:49 PM   #8911
Dean'smeanmachine
Dean'smeanmachine's Avatar
some metal work on the floor support today
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline
Old 12-30-2013, 11:50 PM   #8912
Dean'smeanmachine
i didnt take a pic today so i just used this one of the inner rocker section
Dean
in God we Trust
Old 12-30-2013, 11:53 PM   #8913
tincan1966
tincan1966's Avatar
After fixing a "new" oil leak, took the '65 and went to a friends and bought a C20 rolling chassis. Starting a new dually project. It already has a good 14 bolt in it on coil spring rear. My C30 disc brake FE will go right in it. I have a 6.5 TD and an Allison for it already.
Will post a build thread when it actually starts.
tincan1966 is offline
Old 12-31-2013, 11:08 AM   #8914
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Worked on my friends 62, doing a disk/bag conversion.
Started My 66 to make sure the battery isn't dead.
Also looked at my 65 and 63 sitting there begging for attention like loyal dogs.
Gotta get my Bud's 62 out of my driveway first..
New Year Resolution #1..... work on my own stuff
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 12-31-2013, 02:39 PM   #8915
steveb64
steveb64's Avatar
You remind me of myself. Nice truck!
steveb64 is offline
Old 12-31-2013, 02:57 PM   #8916
scotts62
One day...
scotts62's Avatar
Got the battery box tacked up and mounted
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 12-31-2013, 08:23 PM   #8917
rickywideglide
rickywideglide's Avatar
installed new sending unit, but truck wont start getting a lil gas from line at carb.,not sure if theres not enough gas or if somethings wrong with fuel pump
rickywideglide is offline
Old 01-01-2014, 12:01 AM   #8918
mud.man.rj
mud.man.rj's Avatar
Should have still had fuel in old pump to start it up, maybe something to do with the sending unit pickup, I would try filiing the fuel line up first from carb down to the pump just to prime it and see if it continues to run, hope so if not when it use the bit of fuel used to prime it then back to pump or tank.
5.0 4spd std.
7" lift w 35's.
Old 01-01-2014, 10:41 PM   #8919
Lugnutz65
Lugnutz65's Avatar
Pressed the last few pieces off the main shaft of my soon to be rebuilt Camaro T5 with an S10 tail housing swap. I will order the rebuild kit tomorrow and finish cleaning parts until the kit arrives. This is a great learning project for me.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 01-01-2014, 10:58 PM   #8920
slick willie
Today my offspring drove her truck for the first time since converting to a big back window and lowering. I have not posted any pick but I will post a before and after pic.Name:  image.jpg
slick willie is offline
Old 01-01-2014, 11:02 PM   #8921
Chevy Fleetside
I put mine to work again.
Old 01-01-2014, 11:04 PM   #8922
Dean'smeanmachine
Originally Posted by chevy fleetside View Post
i put mine to work again.
i love your truck!!!! Sweeeeeeeeeeeeeet
Dean
in God we Trust
Old 01-01-2014, 11:32 PM   #8923
chevyrestoguy
chevyrestoguy's Avatar
I've been underneath the rear of the truck for the last few days installing C-notches. I've done so much grinding, drilling, air chiseling, and cutting that I feel like I've gone 12 rounds with Mike Tyson. Almost done!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline
Old 01-02-2014, 12:10 AM   #8924
Chevy Fleetside
Thanks... I love driving it.
Old 01-02-2014, 12:14 AM   #8925
Rich 5150 69
Rich 5150 69's Avatar
With the bed on.....? Why..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Closed Thread
