12-29-2013, 12:43 PM | #1 |
cab swap question in mo
I need to swap cabs on a71 4x4. The one I have is junk. I have a good one I purchased a few years ago. It does not have a title. I have a hand scribbled bill of sale from po. it has vin tags on it I had heard some years ago you can take your truck and new cab to troopers head quarters and have everything checked and they will swap tag for you. has anybody done thishere in Missouri.
12-29-2013, 12:48 PM | #2 |
Re: cab swap question in mo
Edited by staff
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale Last edited by ETsC10; 12-29-2013 at 08:27 PM. Reason: suggesting ILLEGAL vin tag swap |
12-29-2013, 01:20 PM | #3 | |
Inquire with your DOT most likely they will be in the theft division. They should be able to direct you how to legally do it.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
12-29-2013, 01:28 PM | #4 |
Edited by staff
Last edited by ETsC10; 12-29-2013 at 08:28 PM. Reason: suggesting ILLEGAL vin tag swap |
12-29-2013, 02:13 PM | #5 |
To complicate things even more, apparently its had a cab swap before in Illinois. the vin tag on it is on the door pillar by the windshield. it matches all the other #s on the truck and title. Hopefully they can verify donor cab is ok and just move that tag to the new cab. Im doing a frame off total nut and bolt restoration on this truck and want to do it right.
12-29-2013, 05:20 PM | #6 |
Like to know how this works out for you, was wondering the same thing, on somthing else we were thinking about doing? keep us posted on what you did.
http://67-72chevytrucks.com/vboard/s...0&referrerid=0 |
12-29-2013, 07:55 PM | #7 |
Last November Mo started a visual VIN Tag inspection by a Law Enforcement Official on anything more than a certain number of years (25+?) when transferring a title from a non-Mo state titled vehicle. I have not went through this process yet personally but heard at a local car show it had started. A crack down on VIN plate swapping. If so a couple suggestions would be to talk to a local law enforcement type or DMV office. They may show at your house at your request, verify clean VIN for you and point you in the right direction.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-29-2013, 08:57 PM | #8 |
I have all the info on applying for a lost title in MO. I purchased a 69 c/30 camper in IL. it had been sitting for 20 years and was last titled in Texas . It was a nitemare trying to figure out how to do this .
