Old 12-29-2013, 03:24 PM   #1
grs
Air cleaner riser.
Where can I buy an air cleaner riser for a Rochester carb. I have a 327 eng. It now has HEI dist. The plastic riser I now have hits the choke linkage.
grs is offline   Reply With Quote
Old 12-29-2013, 04:40 PM   #2
cool68
Re: Air cleaner riser.
should be available at local auto parts store. or try a site like summitracing.com
four barrel? stock air cleaner, or aftermarket? if aftermarket use a flat base instead of the concave style to raise air cleaner.
cool68 is offline   Reply With Quote
Old 12-29-2013, 09:32 PM   #3
grs
I can't use a stock air cleaner, because it will hit the HEI distributer. The plastic riser that I have hits the choke linkage.
Old 12-29-2013, 10:39 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
http://www.summitracing.com/search/p...aner%20Spacers
Old 12-29-2013, 11:57 PM   #5
tlawre87
tlawre87's Avatar
When I put HEI on mine I had the same issue. I bought a riser off ebay. (I believe a mid 70's truck?)
Here is one for sale like I got. I like it too as it gave me the tube for the breather
http://www.ebay.com/itm/Air-Cleaner-...item417adfcb2e
Edit:
Too add. I bought the Mr. Gasket riser set from advanced auto. It fit horribly on my quadrajet. It wouldn't seat well. That's when my Dad gave me the idea on the factory riser.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
Last edited by tlawre87; 12-30-2013 at 12:03 AM. Reason: i remembered something :)
tlawre87 is offline   Reply With Quote
Old 12-30-2013, 12:51 AM   #6
wraprail
wraprail's Avatar
If you have a pic-a-part yard (or any wrecking yard) close by these are very common item in several different sizes. Came on many GM cars and trucks
wraprail is offline   Reply With Quote
