Old 12-30-2013, 06:24 PM   #1
Juiceball
Truck runs fine for about an hour or 90 mins then dies
Anyone had this issue? My '83 K20 has an older 454 in it with an HEI. The truck will run fine for about an hour or so then sputter and die. When it starts to sputter, there are surges of power like the spark is flipping on and off. When it dies, it will start again after a while but won't run again without sputtering and dying until it cools off for several hours. I changed the ignition module and switched coils (using an old coil from another Chevy that runs fine). Going to put a new cap, rotor, and coil on just to be sure, but I'm thinking it might be the condenser? Will heat affect that and would it even be the cause? Could it just be a bad wire somewhere that is getting hot? When it runs it runs fine, smooth, and strong so I don't think it's a fuel issue, but maybe?
Thanks, I'm stumped!
Juiceball is offline   Reply With Quote
Old 12-30-2013, 08:55 PM   #2
Just1more
Re: Truck runs fine for about an hour or 90 mins then dies
There are a couple of things you need to check. When the truck dies, is it losing spark or fuel? To check if it's losing spark, pull a plug wire and put a good spark plug in it. Ground the base of the plug to the block and crank it over. If you see a bright blue spark jumping the gap on the plug, you have spark. Now, a quick check for fuel. When it dies, pull the breather off and pour a teaspoon or so of fuel down the throat of the carb, then crank it over. If it fires and tries to run, you probably have a fuel problem.
If we figure out which one you are losing, we can help you figure out why.
2005 2500 CCSB 4x4 Dmax/Alli, EFI-Live
2011 VW Golf TDI 6 speed manual
91 V3500 Crew cab Dually, 4X4, 454, 4L80E
87 V1500 Reg cab, 4X4, 350, 700R4
82 K1500 Reg cab, 4X4, 400, 700R4
Just1more is offline   Reply With Quote
Old 12-30-2013, 11:43 PM   #3
Juiceball
Question Re: Truck runs fine for about an hour or 90 mins then dies
Haven't tried the spark plug trick but it will start again after it dies. I can compression start it a few times as I'm rolling to a stop. If it only sits a few hours it will start, idle, and take off, but only a few 100 yards before dying again. If it is a fuel issue, what would cause it to die after running perfectly for over an hour, at speed and under load? (New filter, new gas tank sender).
Old 12-31-2013, 12:01 AM   #4
Just1more
You said you replaced the ignition module, did you replace it with a new one and did you coat the metal plate with the special heat transfer grease? I have seen those act similarly, they run fine until they heat up and then do all kinds of weird things.
Old 12-31-2013, 12:14 AM   #5
Juiceball
Yep. New module and used the grease. The condenser lead was all twisted up and routed between the base plate of the distributor and the top of the engine so it was sitting right on top of the motor. I rerouted it so it went directly from the base plate to the cap. Was going to replace that (and condenser) next to make sure there isn't a broken or frayed wire that's getting to hot and choking out the signal from to many ohms due to heat.
Old 12-31-2013, 12:26 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
years ago I had an f250 that had a similar issue with a condenser that was getting hot off the exhaust manifold and blowing a fusible link.. I would check the fuel pressure to rule it out but im betting that the condenser.. the other thing im suggesting you check is the whole distributor make sure there is no up and down play in the shaft
One other thought the coil you put in are you sure its good? Ive had several that came off the shelf in the suto parts store that were defective those were made by KEM since that incident years back I refuse to use anything other than AC Delco in the GMs
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-31-2013, 09:35 AM   #7
mrolds88
I kinda think its a fuel issue. 100 yards wouldn't heat anything up far enough to make it die (electrically), I wouldn't think. Also, to do the spark plug test, if you don't have a spare plug, just get a buddy to hold he end of the wire, but you have to do it early in the morning!! LOL Might not work any better, but will be more entertaining.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-31-2013, 11:11 AM   #8
hartbraker
May be a stupid question, but could you guys elaborate on what condenser you're talking about? Pics would be nice... what does it do?
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 12-31-2013, 01:43 PM   #9
SkinnyG
SkinnyG's Avatar
If you are running out of fuel (no fuel squirting in the carb when you move the throttle by hand),
Try driving with the gas cap off.
If the tank isn't venting, at some point the fuel pump cannot overcome the vacuum created in the tank by the exiting fuel, and the engine starves. After a number of hours, the tank eventually equalizes pressure through what little remains of its vent, and you can drive for a time before it starves again. Removing the gas cap allows the tank to take on air as fuel is drawn out.
If nothing else, it's an easy test.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-31-2013, 10:14 PM   #10
Juiceball
Good point, here it is...you plug one end of the ignition control module into the condenser and pigtail plugs into the cap.
Old 12-31-2013, 10:22 PM   #11
Juiceball
Will try that but I just changed the sender unit and all flexible hoses. Vent cap seemed to be working. The other problem I haven't fixed is the starter. With the big block and headers the hot line to the solenoid or the solenoid itself gets to hot after running for a while so it has to cool down also. Going to install heat shield and heavier guage hot wire. Anyway, by the time the motor quits, so does the starter, so it's hard to turn it over right away after it dies. Best thing I can do is compression start it while still rolling which works a couple of times but it ultimately gets to the point where the motor just jake brakes the truck to a stop.
Old 12-31-2013, 10:26 PM   #12
Juiceball
Thanks for all the ideas so far, gonna hit it again after coming to tomorrow::
