Old 05-23-2009, 12:35 PM   #1
1967C20
Junior Member
1967C20's Avatar
How to mount voltage regulator
I know this might be a dumb question but.....How does the voltage regulator mount on our trucks? I took the old one off about a year ago (the rubber mounts disintegrated while removing the bolts) and set it aside while I did other things. I ordered a mounting kit which came with 3 screws and 3 t-shaped rubber grommets about 3/4 inches long. I seem to remember the factory grommets being H-shaped (sandwiching the core support). Any one know how the new kit mounts or did I get the wrong part - DOH
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 12-31-2013, 12:26 AM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: How to mount voltage regulator
Old post but I am wondering about this myself. Can't seem to figure out how they mount. Thanks
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-31-2013, 01:02 AM   #3
cool68
if new, hopefully, there should be instructions in box
cool68 is offline   Reply With Quote
Old 12-31-2013, 01:07 AM   #4
1972SUPERSB
Regulator came with instructions but doesn't show how to mount the rubber insulators.
Jeff
Old 12-31-2013, 01:26 AM   #5
FirstOwner69
FirstOwner69's Avatar
What you have is correct. The T-shaped grommets are actually well nuts. Put them into the holes in the core support from the engine side. They should be barely snug. Insert the screws through the regulator base and screw them into the well nuts. As you tighten them the well nuts expand.
FirstOwner69 is offline   Reply With Quote
Old 12-31-2013, 01:33 AM   #6
1972SUPERSB
Cool I will try that. Thanks
Jeff
