Old 12-30-2013, 06:06 PM   #1
kevinr1970
Lowering leafsprings
Looking to lower my 2wd '82 K5.
I was going to do a flip kit, and new springs at the same time, but saw 5" lowering leafs.
What are the drawbacks of lowering leafsprings?
http://www.performanceonline.com/197...af-Spring-Set/
Also, anyone have any problems with performance online?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 12-31-2013, 08:11 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Lowering leafsprings
I think, generally, you want to maintain the same load and travel characteristics. I'm actually not sure if flatter springs are a better or worse way to do that compared to blocks.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 12-31-2013, 08:33 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The rear frame rails are different on a 2wd blazer compared to a truck.
A flip kit it the cheaper method, but you will need a c-notch and the center section of the rearend is closer to the floor on a K5 than it is on a truck.
Plus you will have to lower the front ALOT to match the height of the rear.
I think drop leaf springs is a better choice.
Just make sure you get 52" leaf springs.
Trucks could be order in 52" or 56".
You can run a drop shackle also,... but then you get into the fuel fill hose on the passenger side.
This can be cured with some creative routing of the fuel fill line using exhaust tubing.
Keith
Convert to disc brakes.
Old 12-31-2013, 01:51 PM   #4
kevinr1970
I am doing 2-1/2 spindles and 2" springs in the front, and they listed 5" leaf springs.
With a slightly bigger tire in the rear, I hope to sit level.
I am actually wondering what the arch would look like on a 5" lowering spring, it seems like it would need to be a negative or reverse arch to do that?
2000 Tahoe Limited
