camper mirror hardware
What are you guys using for hardware to attach your camper mirrors? Mine have these awful looking lag bolt giant screws. They are no longer biting into the door and loosen pretty quick. I dont want to go up a size so looking into a more elegant solution.
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: camper mirror hardware
For camper and below eyeline mirrors the lag screws are correct GM. If you don't want to upsize 1) remove the door panels and tackle attachment with a nut and bolt or 2) weld up the holes, drill 'em out, and reuse the OEM lag screws.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
lol wow can't believe they are OEM. Looks like ill do a bolt and nut solution. Thanks!
Carpe manana
You bet! Good luck
![]() Join Date: May 2010
Original was the lag bolt as noted above. I agree it was a lousy attachment method. When I did mine I noticed that the late 70s vans used what I have pictured below. Since I was looking for a better solution than the original and wasn't trying for a absolutely correct restoration I did it like the vans were. This way the doors are sealed from the elements (the exposed part is soft vinyl coated) and the mirror legs do not contact the paint. The inserts are available at NAPA stores. The bolts shown are from a van.
Carpe manana
x2 - I used vinyl washers for my K20 build.
Just to clarify what I showed in my post above (#5). The first picture in post #5 is of a jack nut that requires a larger hole, is installed and then expanded inside the door. It requires a 1/4" bolt and provides a secured nut to bolt to.
Here's a link to the jack nut and a picture on my below eyeline mirrors installed. http://www.napaonline.com/Catalog/Ca...629_0006391353 |
Nutserts
Thanks for the ideas. I was thinking of how to "thread the hole". I'll swing by Napa and see what they have
![]() ![]() Join Date: Sep 2008
I think Im going to go with the jack nut solution linked via ebay.
Question about the nutserts. Are those usually riveted into more substantial material, i.e. metal tubing or thicker sheets of metal. Does a door skin really have enough meat to hold a nutsert? Just curious never used them before. Thinking out loud, would they distort the door skin when you rivet it on? |
![]() Join Date: Jul 2001
Just a thought but when I installed my camper mirrors on my '71 4x4 I used small rubber washers or grommets between the mirror arm and the steel door skin. Also used stainless bolts and nuts, got them from local Fastenal store. Keeps the door skin sealed from rain, snow and care washings. Also holds the mirror brace away from the door skin so dirt and such does not lodge between the mirror brace and door skin. Slight opening or cavity of about 1/8" or so allows water to wash past keeping area clean.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#15 | |
| Bookmarks |
