Old 12-23-2013, 10:31 PM   #51
oldman3
oldman3's Avatar
Re: 47 Step van
Brake set up is something else, nice job. Panels look great...Jim
oldman3 is offline   Reply With Quote
Old 12-25-2013, 12:20 AM   #52
skymangs
skymangs's Avatar
Re: 47 Step van
Wow, those floors are a work of art! looks great
skymangs is offline   Reply With Quote
Old 12-25-2013, 12:37 AM   #53
99 to Life
99 to Life's Avatar
Re: 47 Step van
looks great, as always. I'm digging the old chevy gauges in there, those stayin??
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-25-2013, 03:31 PM   #54
xpickup
xpickup's Avatar
Re: 47 Step van
Hope everyone had a Merry Christmas, my family did.
Oldman3, thank you. Yes, the brake peddle assembly is something a little different. That is what I came up with. It is because of how far front and how high you set.
Skymangs, thank you. I love making the floors.
99 to life, thank you. Nope, they are going. New dash( just a little longer) and new gauges.
Shannon
xpickup is offline   Reply With Quote
Old 12-30-2013, 09:19 PM   #55
xpickup
xpickup's Avatar
Re: 47 Step van
Still plugging away on the truck while I am on vacation. I made the radiator support/ front body support. It sandwiches the radiator/ wheel well area to hold the front of the body. Then mounts to the frame. I have a section that holds the radiator down into the support. I also have some holes for a filler panel that will go to front of the truck so the air is pushed through the radiator. I have it all mounted in now. Then I started on the steering. I took a universal joint and cut it apart so it will just be a coupling. Tomorrow morning I am going into where I work to turn it down and make a sleeve, then I will TIG it together. Hoping to have the steering in tomorrow. I also am going to make a connecting rod as the drop for the column. So I need to make an aluminum spacer for it. I also worked on the custom hood for my lowered dually because it was raining. I had a steel dual cowl scoop giving to me but it was too long. So I shortened it up and widened it and made 2 intakes in the front. Kinda a cross of a cowl hood and a 442 hood. I love sheet metal!
Shannon
Old 12-30-2013, 09:22 PM   #56
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-30-2013, 09:30 PM   #57
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-30-2013, 09:36 PM   #58
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 12-30-2013, 10:21 PM   #59
99 to Life
99 to Life's Avatar
Re: 47 Step van
perhaps your sick of hearing....... very nice work!!!!!
Old 12-31-2013, 12:19 AM   #60
oldman3
oldman3's Avatar
Re: 47 Step van
Shannon, you make everything look so simple, very nice. Hood looks great...Jim
Old 12-31-2013, 06:41 PM   #61
48 GMC BURB
48 GMC BURB's Avatar
Re: 47 Step van
Shannon,,That Hood won't fit !!
Originally Posted by xpickup View Post
Shannon
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 12-31-2013, 07:05 PM   #62
48 GMC BURB
Re: 47 Step van
Shannon
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 01-01-2014, 12:36 PM   #63
xpickup
xpickup's Avatar
Re: 47 Step van
Happy new years to everyone!
99 to life, haha, thank you.
Oldman3, thank you. I can not wait to do the filler and paint work on the hood and get it on.
48 GMC BURB, sure it can , just a little more cutting.
Went into work yesterday morning so I could use the lathe and mill. Turned up the ex universal joint. Then turned up a tube to press both ends into. One end is 3/4 30 spline and 3/4 36 spline. They did not make a coupling, so I made one. I am using a clear steer offset box. It is 14 inches from offset to offset. Worked like a dream. I had to make up a bracket to bolt to the frame and the radiator support so it is nice a strong. While a work I also turned up some split bushing for the upper and lower column supports. Ken liked the connecting rod one on the 51 so I am doing another one for this truck. I have to make the upper dash support yet and then I will mount the connecting rod to it.
Shannon
Old 01-01-2014, 12:43 PM   #64
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-01-2014, 12:51 PM   #65
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-01-2014, 01:07 PM   #66
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-01-2014, 02:37 PM   #67
oldman3
oldman3's Avatar
Re: 47 Step van
Shannon, looks good. I always wondered about the offset steering unit, at least now we have some feedback on how it works. Happy New Year to you and the family...Jim
Old 01-01-2014, 07:26 PM   #68
skymangs
skymangs's Avatar
Re: 47 Step van
Shannon, your fabrication skills boggle the mind! Looks great!
Old 01-01-2014, 09:52 PM   #69
48 GMC BURB
Re: 47 Step van
Looks good Shannon,as usual . I'll see you Sunday with a truck full of goodies
Shannon
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 01-01-2014, 10:24 PM   #70
xpickup
xpickup's Avatar
Re: 47 Step van
Oldman3,thank you, this is the second time I have used an offset box. This one is from wizard fabrication. You an get them every 2". I used the 14" which worked out great. The other one I used is from cen- pen speed shop and there's only come in 5" offset. Both are great units for the pita steering set ups. Worth the money.
48 GMC BURB, thank you, sounds good. I love hearing more parts!
Shannon
Old 01-14-2014, 10:32 PM   #71
xpickup
xpickup's Avatar
Re: 47 Step van
It has been a while since I posted. I have busy with this truck and my 1996 lowered dually. The dually is going to be my daily driver when I get all the bugs out. Well back to the box truck, I made a new dash. It is longer than the factory one that way I could get the air ride stuff in. I then made a 1x1 box tube structure for the upper steering column mount. I then shortened up the connecting rod to fit. I then fit the new dash. After that, I began to work on the drivers inner wheel well. I had to cut a bunch of it out when I put the clear steer box in. I also had to gain some room for the brake pedal too. I made a new front panel and riveted in. I also made a new side cover too, it is removable. I used those nuts that have a clip on them that slide over the sheet metal. It makes it great if you have to get into the side of the motor and brakes. I then pulled everything back apart and primed and painted it. Now I can put it all back together for good now.
Shannon
Old 01-14-2014, 10:34 PM   #72
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-14-2014, 10:47 PM   #73
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-14-2014, 10:53 PM   #74
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
Old 01-14-2014, 10:58 PM   #75
xpickup
xpickup's Avatar
Re: 47 Step van
Shannon
