89 CC C30 e-brake cable
Anyone know the trick to disconnecting the e-brack cable on these trucks. My experience w/the pre-75's is a simple bracket/retainer. My dually has some sort of clip/retainer that is not much larger than the cable. It had enough gap to fit an awl in there (I though maybe it pops off) but I felt like I was going to break the awl off trying to do so.
What's the trick before I tear something up?
Re: 89 CC C30 e-brake cable
Anybody? Does this piece (#5 parking brake cable pic) actually pry off & is re-useable or is it usually destroyed during the removal process?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-01-2014 at 01:50 PM. |
I used a pair of channel-locks. You have to catch the pellet on the cable through the slot and squeeze it to the center of the sleeve. Then it will come out through the rectangular opening. Hope this makes sense, Buddy
I know the "VOICES" aren't real but they have some great ideas. 1978 GMC Sierra Classic C25 1983 Datsun 280ZX Turbo 1997 Chevy Cheyenne K2500 1999 Polaris Sport 400 |
Make sure parking brake pedal is all the way up. Then pull the cable at #5 sideways. This pulls the cable out of the sheath. Put a pair of vise grips on the cable right at the end of the sheath. This will give you room to work. Being careful, use a small screwdriver to lift the little tab that locks the cable end in. Then slide the cable out. I had to do this on one of my trucks when the adjustment nut rusted to the threaded rod.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#5 | |
I guess I'll spray everything down & try again now that I know the clips are available.
Worse comes to worse, Rockauto has them for less than $2 each.
That was my next place to look. Went by OReillys & they gave me that weird look. I know part of the problem was I don't know the correct GM term for that clip (I was explaining to them I needed an e-brake cable retaining clip so they were telling me they're in the HELP section).
