#101 |
Re: My 63 Project
Put my new springs in today. This is the frame before.
#102 |
Re: My 63 Project
And mocking up the new springs. Supposed to be four inch drop springs.
#103 |
Re: My 63 Project
And now the frame... After the install. Does my math not add up???
#104 |
![]() Join Date: Mar 2005
Re: My 63 Project
To get an accurate measurement, you're going to need to have the bed installed and be at close to your final weight on the rear suspension. I think you're going to be OK.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#105 |
Re: My 63 Project
I am pretty happy with the look... and we shall see what the final looks like after we get the bed and some real tires and wheels.... I was worried about going too far with 4"....
#106 |
Re: My 63 Project
Shaving some bumper bolt heads. Two down, four to go.
#107 |
Re: My 63 Project
Getting pretty good with this "rattle can" primer!!!
#108 |
Re: My 63 Project
And the dash.
#109 |
Re: My 63 Project
Spent some time today working on my door panels.
#110 |
Re: My 63 Project
Notice that one of them has holes for the arm rest. That has to go.
#111 |
Re: My 63 Project
Little bit of welding.
#112 |
Re: My 63 Project
Little bit of grinding.
#113 |
Re: My 63 Project
Little bit of filler.
#114 |
Re: My 63 Project
Little more sanding, ready for primer and paint!
#115 |
Re: My 63 Project
And with a couple coats of paint.
#116 |
Re: My 63 Project
Ok, so now I need some help.
How do I get the gas tank mounts out?? Obviously there are two bolts that come up from the bottom, but it looks like the mounts are spot welded to the rear of the cab. |
#117 |
Re: My 63 Project
I think they are spot welded to the floor as well... IIRC 66Farmer did the cleanest removal of those that I have seen on this site.
If you dont already have a spot weld cutter, you may want to get one.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#118 |
Re: My 63 Project
Just found your build...
![]() Great start, I'm in for the ride... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#119 |
Re: My 63 Project
Thin layer of filler on the fender.
#120 |
Re: My 63 Project
Workin on the door.
#121 |
Re: My 63 Project
About four hours with that air file in my hands is about all I can take. It will wear you out!!
#122 |
Re: My 63 Project
I picked one up today Murph. I will post pics as I take them out.
#123 |
![]() Join Date: Mar 2013
Re: My 63 Project
Nice work! Yer doing great!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#124 | |
Re: My 63 Project
A light hammer and a sharp punch will usually give you enough of a indent for the weld cutter to ride in until you get a good circular channel started. But not always, so keep another drill handy with a bit in it that is just a tad larger than the spindle on the weld cutter. This will give your weld cutter the stability over uneven spots to get the job done. On the back of the cab be very cautious when cutting else you will be plugging holes you didnt need to (I tried using an air chisel and learned the very hard way). Remember the spot weld cutter is sharp, and fast, if you are not paying 100% attention you will cut dime size holes clean through both layers of steel. In my tiral and error learning I found that it was better to under cut it, and tap tap tap with a chisel between the two welded pieces, than it was to cut all the way thru. I hope this helps you (hopefully you read this before you get hands on the project) and good luck !! Here is the build I was looking for, a great fellow doing an awesome build: http://67-72chevytrucks.com/vboard/s...=513377&page=6
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 Last edited by McMurphy; 01-24-2014 at 03:44 PM. Reason: Found the reference link |
#125 | |
Re: My 63 Project
