Old 01-02-2014, 12:02 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 350 Block Question
GM had a brain fart and used metric plugs on some engines. I think its a 16mmx1.5 or 18mm x 1.5 pipe plug not straight thread
Old 01-02-2014, 10:42 PM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Really? Ohhhh-kay. That's a new one on me. Maybe a modern block? Because all of the older blocks used SAE sizes.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 01-03-2014, 09:32 AM   #3
burnin oil
I have found that brass seals perfectly as Marv says. Now the problem is in pipe style fittings that are tappered. One cut to big or small and it will leak like hell. I had this exact issue when installing an onboard air tank in my 5500. None of the fittings would seal.
The bushing works as long as you have the small sensor and a big hole. I have the opposite problem
burnin oil is offline   Reply With Quote
Old 01-03-2014, 11:14 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
hahaha sounds like someone is trying to fit a Automerter temp gauge in a LS1 head?. Can you believe you have to buy a special temp sensor from Autometer just for the LS heads!!! what a $21 crock of extra cash-flow!
Storm,, Wasn't trying to target teflon tape specifically,, just saying brass into iron and you really don't need anything. I've seen guys tap the pipe threads too deep with the tapered tap to loosey-Goosey, and then try to use 15 wraps of teflon tape to 'take up the space' . Then wonder why the gauge doesn't work. There are a myriad of sealing compounds and ideas,, none of them are 'good' for a electrical connection. But I do agree, Teflon tape (2 wraps like your supposed to do) is probably the least offensive to making ground. It only takes what,,,,,, 1/16 square inch of solid contact to make good ground.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-03-2014, 03:53 PM   #5
burnin oil
No New alum heads for my 400sb have the small sender hole. My new autometers do have the small sender. Just have to get around to finishing my new cluster. Have ya seen the oil pressure gauge for the LS? That one looks like a PITA!
