Old 01-01-2014, 08:00 PM   #1
74baggedbug
Gear swap price?
What's everyone paying for gears? Looking to get 373's already have posi-trac and it's a 10bolt .. I've had prices ranging from $350 up to $1000.. Thanks for any info/help
74baggedbug is offline   Reply With Quote
Old 01-01-2014, 10:57 PM   #2
hugger6933
Re: Gear swap price?
I would think more toward the lower side than the upper. You can buy a set of gears from either Jeg's or Summit for around $125 to $150 and that much more should get them set. Jim
hugger6933 is offline   Reply With Quote
Old 01-01-2014, 11:19 PM   #3
74baggedbug
The shop that wants closer to 1000 also will replace the bearings and is considered 1 of the best in the Houston area..
Old 01-01-2014, 11:28 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I was told ~$900 to do a similar swap for both axles in a 4wd. I was able to locate good gears on the parts board to reduce that expense. Good luck, Pete
Old 01-02-2014, 04:43 PM   #5
74baggedbug
Anyone else???
Old 01-02-2014, 05:50 PM   #6
cdowns
cdowns's Avatar
most of these trucks use a 12bolt posi not a 10bolt
Old 01-02-2014, 06:10 PM   #7
74baggedbug
The P.O. did the swap and the 10bolt has disc brakes..
