Old 01-03-2014, 11:18 PM   #1
1moretoy
Auto Meter temp sensor
Hey guys I bought an auto meter gauge and temp adapter. I had to drill out the adapter to fit the sensor but the probe is not long enough to stick through. Does it need to or will it be ok how it is. Im Worried it wont read correctly.
1moretoy is offline   Reply With Quote
Old 01-04-2014, 02:12 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Auto Meter temp sensor
As long as the sender matches the guage, you will be ok. Auto meter lists a short sender to fit that app (no drill to fit), & that works fine on my setup? The sender does not fit as deep as what your pic shows....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-04-2014, 10:02 AM   #3
Clyde65
Clyde65's Avatar
Ditto CL, this is what I did on mine.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-04-2014, 11:13 AM   #4
1moretoy
Should I use teflon pipe dope or tape on the threads. The adapter did come with a copper crush washer.
Old 01-04-2014, 02:20 PM   #5
Billett
Billett's Avatar
I didn't. I bought the separate autometer adapter but for some reason my gauge reads about 15° lower than the pcm... pcm sender is in driver side head and gauge sender is on pass side rear.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-04-2014, 04:28 PM   #6
crazy longhorn
I have not checked, with any temp tools, but do not think that I am running hot? Go to the bottom of the 2nd page....pics on the longhorn swap. The headers have 3 hrs running time....no burnt paint, no issues? The rad hoses, I can hold with my hands(old welder)? No argue here....I am sure that you or I can stand over that mill, and know if it is running hot? Longhorn
Old 01-05-2014, 10:24 AM   #7
solidaxel
solidaxel's Avatar
Times three, and not tape on mine and no leaks BUT I only had it up to 160*
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-07-2014, 01:33 AM   #8
doubeys_nova
I had to drill mine also. Works perfect.
doubeys_nova is offline   Reply With Quote
Old 01-07-2014, 11:14 AM   #9
mooseknuckles
mooseknuckles's Avatar
x2
mooseknuckles is offline   Reply With Quote
Old 01-07-2014, 11:41 AM   #10
doubeys_nova
i used a drill bit a little larger than the probe. i held the fitting with vice grips and let it self center on the bit using a drill press. hope that makes sense.
Old 01-10-2014, 07:02 PM   #11
crazy longhorn
Just for thought....with a 2259 sender(for 90 degree sweep gauges), no need to drill the adaptor? longhorn
