35x12.5 tire
I am thinking of ditching my 16.5x8.75 for a set of 15x12 rims. The question I have is will a 35x12.5 work and look ok on a 12" rim? Eventually I plan on going to a 37x13.5 when the price gets more reasonable.
user # 2756
![]() Join Date: Jun 2001
Most manufacturers recommend 10" wide rims for a 12.5 tire. I've seen 12.5 tires on 12" wide rims and for street driving should be fine but you get the truck a little off camber and you'll probably loose the bead, wouldn't take much. Probably couldn't use the full load rating of the tire either. Even the 13.5 tire would be the same as the 12.5. Tires I've seen that recommend 12" wide rims are for example the 33/15.5-15 super swampers and in that case its 10-12" wide rim. Be careful.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Suburbans RULE!
I agree with Jim. A 15X12 rim is too wide for a 12.5" tire. I would go with a 15X10 or 15X8. Personally, I went with a 15X10 for my 35X12.5's.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
#4 | |
Re: 35x12.5 tire
IF YOU HAVE 8 LUG ROTORS AND CAIPERS IN FRONT THE 15" WHEEL WONT FIT OVER THE CALIPERS
![]() Join Date: Feb 2000
What are you doing with your old 16.5's? and where are you located?
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#7 | |
http://members.cardomain.com/chevyjeff 57 2 DOOR HDTP 82 CORVETTE 90 V10 BLAZER 97 REGAL LSR 2100 (BOAT) |
My old 16.5's will be up for grabs. I live south of Atlanta GA. Thanks for the info. on the 15's not fitting, back in the day I had a old drum type 2 wheeler, I didn't think about the calipers. Thanks again.
wheels
hey no prob maybe you can just send the wheels to me and we will be square how does that sound? lonn
king $h!t
u can make 15inch rims fit the 8 lug set up just grind the backs off the calipers. just dont take to much
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
#11 | |
Suburbans RULE!
Thanks all for the info!
I am looking at a set of American 15x10 81series wheels with a 4" back spacing Pete Paulsen has them for $77 each. Summit also has Bart's with 3 1/2 back spacing for $99 each. Thanks again ya'll, Dana
Dana 77 K-20 454 73 SS El Camino 454 68 SS Camaro 327 48 Chevy 216 755 John Deere |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Beast388 what kind of axle stands are those? What Weight/size they are too...
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. Last edited by Canadian694x4; 12-19-2003 at 09:05 PM. |
#14 | |
Suburbans RULE!
Uh...those are just some cheap 2-ton AC Delco jackstands that I picked up at O'Reilly's for $20.
#15 |
user # 2756
Here some I bought at Sam's for $30 I believe:
http://67-72chevytrucks.com/vboard/s...threadid=73812
