01-05-2014, 09:33 PM | #1 |
Front Sway Bar?
Hi all, happy new year. Have a question for you guys. Have a 1972 Cheyenne Super SWB. Did this truck ever come with a front sway bar? If not could I put one on it from a another 67-72 C10?
Thanks Eddie |
01-05-2014, 09:35 PM | #2 |
Re: Front Sway Bar?
Yes, you can. It will bolt right up. All the holes are there.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
01-05-2014, 10:32 PM | #3 |
Re: Front Sway Bar?
you can pull one off of any square body Chevy truck too. Mine on my 71swb came off of an 81 3/4 ton
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438 |
01-05-2014, 10:50 PM | #4 |
Re: Front Sway Bar?
All the holes are there, but you will have to cut one rivet on each side at the cross member and frame connection. Not a big deal. An air chisel will take the head right off the rivet, and you can punch it out.
01-05-2014, 10:53 PM | #5 |
Re: Front Sway Bar?
Find a BIG one off a square body one ton. The last one I put on I bought the brackets at the Chevy dealership, that was only a couple years ago so they may still stock the brackets .
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-05-2014, 11:10 PM | #6 |
Moderator
Re: Front Sway Bar?
Yes they did and they are a MUST, your ride will improve drastically. As mentioned, they were common in later trucks. I saw 3 in the junkyard last week.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-06-2014, 12:54 AM | #7 |
70+ ( Old Skool Club )
Re: Front Sway Bar?
Check the FAQ section on the site. Member Texas Firefighter has an in depth-faq that I used when I installed my front sway bar. This is one of the best inexpensive upgrades you can do to your truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-06-2014, 10:04 AM | #8 |
Re: Front Sway Bar?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
01-06-2014, 10:06 AM | #9 |
Re: Front Sway Bar?
X2... mine was an 1 1/8" off an early 80's 2wd 1 ton. I had to fab the frame brackets..
01-06-2014, 10:26 AM | #10 |
2WD Jimmy
Re: Front Sway Bar?
You can also buy a swaybar kit from ECE or Hotchkis or Porterbuilt etc.
01-06-2014, 03:20 PM | #11 |
Re: Front Sway Bar?
My $.02. bought a used bar 1 1/8. I bought the rest from local Chevy dealership. The rubber grommets # 3927019,the brackets for the grommets #334671,and the frame brackets #6271375,You need two frame brackets. This worked great on my 67 lwb.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
01-06-2014, 06:56 PM | #12 | |
Re: Front Sway Bar?
very nice! just found something to keep me busy the next coupla days
'69 c10 longbed granny 4spd 292 "Behemoth" '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
01-06-2014, 08:45 PM | #13 |
Re: Front Sway Bar?
Use grade 8 hardware to bolt everything up. it is easy and makes a big difference in handling... I am now planning to do a rear bar as well.
01-06-2014, 09:00 PM | #14 |
Re: Front Sway Bar?
not trying to hijack this thread, but are you gonna use that blade style or regular type rear sway?
01-06-2014, 09:06 PM | #15 |
Re: Front Sway Bar?
