Old 01-03-2014, 01:01 AM   #1
Jsfucttruck
91 Burb-runs great No Idle..Stalls
91 Burb V1500 350/700/241.
Just put new Dist/wires/cap/rotor/plugs/fuel pump/relay/fuel filter/IAC/ Temp sensor, when I swapped to a Edelbrock TBI manifold..
It has a Motorvation stage 2 chip, 195 t-stat, injector pod spacer, tbi spacer.
Timing set to 0.
It will only start if I give it gas and hold the pedal slightly. Runs great if I keep it above 450rpm. It idles and stalls in park at 250-300rpm, driving is not so great if you have to use the brakes or steering while not on the accelerator.
Ideas anyone?
I might have torqued the new IAC on a little too much, could that be the case? Can one damaged the sensor that way?
Could the balancer be slightly spun and I need to give a little more timing?
Thanks..
Jsfucttruck is offline   Reply With Quote
Old 01-03-2014, 01:05 AM   #2
Jsfucttruck
Re: 91 Burb-runs great No Idle..Stalls
I have a fuel pressure gauge at the regulator and it only seems to read around 8.5psi.
When the regulator is on is way out to they tend to allow more fuel pressure in or less?
I am just hoping that I don't have to pull the fuel pump again. I just changed it a month ago.
Old 01-03-2014, 02:35 PM   #3
Jsfucttruck
I tried a new IAC and reset it. No Change.
It won't start unless I give it a tad bit of throttle.
Idle around 250rpm. No steering or brakes when off the gas, the truck dies.
It runs great it if I hold the pedal.
Old 01-03-2014, 03:23 PM   #4
83GMCK2500
Have you gone through and checked for vacuum leaks?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-03-2014, 03:49 PM   #5
Jsfucttruck
I haven't found any yet.
Old 01-07-2014, 01:42 PM   #6
Jsfucttruck
Thanks for all the ideas!
It was the TPS.
