#51 |
Re: Project "Black Cherry" 68 c/10
Not sure if I will use Nelson for a tune, I have a good rapport with PatrickG in Victoria for tuning my LS vehicles.
But I'm curious as to how much Nelson charges for their harnesses. I called and left like two messages, still waiting on a response.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" ![]() 68 GMC K1500 1/2 ton L83/6L80e |
#52 |
Def not going with a Nelson harness, they wanted $1,100 for a simple harness with the fan relays and extending the harness for the computer to fit under the dash.
I'm having a hard time finding the thread where people put what all is done to their build and attach a PDF or Word Doc of the list of all the parts they have installed. Would anyone be able to post a link to that thread please?
#53 | |
#54 | |
#55 |
That's what I heard from a fellow co-worker who is here on the boards as well. I believe their base harness is about $550, I'll need to have them add for the fan relays and the 90mm tb that I changed out.
#56 |
this was the thread I was referring to in regards to people who add their build sheets, good stuff
http://67-72chevytrucks.com/vboard/s...d.php?t=473560
#57 | |
EDIT= Never mind i didnt take in account for the ALT...
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw Last edited by apachedaddy; 01-09-2014 at 07:02 AM. |
#58 |
I was going to just buy the Dirty Dingo billet adapter plates for the ls2 style water pump to be used with the truck accessories, but it will just be cheaper for me to buy the 6.2 newer style pump.
#59 |
![]() Join Date: Apr 2005
The 2010+ Camaro water pump works great (no adapters required - its the same offset), or like stated, just flip the TB 180.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#60 |
Steven, For what it's worth I used 150tunes.com to rework my wire harness for $250 and had no problems except for their busy and it takes a while.
#61 | |
As for flipping the TB, is that possible? Never seen anyone run it like that.
#62 |
Btw, I already ordered all my black -6an fuel fittings, nylon braided fuel hose, vette regulator/filter, and decided to buy a TBSS intake with the rails and injectors since it already has the opening for a 90MM tb and also is meant for a 4bolt design tb as well as it having a return-less style fuel rail on it. I'm gonna ditch my stock 5.3 intake and that aluminum tb adapter plate. Just in case anyone might be interested in it.
#63 |
#64 |
#65 |
Looking good man!
#66 |
A little update, got some nice billet pulleys, and an underdrive pulley.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" ![]() 68 GMC K1500 1/2 ton L83/6L80e Last edited by stevenbear72; 09-25-2014 at 11:59 AM. |
#67 |
I'm clearly too dumb to figure out how to edit a post, or this message board doesn't allow it, anyway, pics...
![]() ![]() ![]() ![]() Also replaced some bolts with some other bolts ![]()
| Bookmarks |
| Tags |
| 5.3 swap, c10, help me please, ls swap, swb fleet side |
