I Corner Scaled my truck LOOK! 3482 Pounds
So I got out the race car scales and threw them at my truck. Here's the results.
![]() LF RF F% LR RR R% 1002 1041 58.7% 731 708 41.3% cross weights LF-RR 49.1% RF-LR 50.9% TOTAL: 3482 ![]() LF RF F% LR RR R% 1067 1052 58.5% 777 724 41.5% cross weights LF-RR 49.5% RF-LR 50.5% TOTAL: 3620 Here's a comparison: 2002 Camaro SS Curb Weight 3,553.9 lbs. Weight Distribution(%Front-Rear) 55-45 1/4 mile: 13.9 @ 98 mph 325 hp My truck is lighter, has 25 more hp and is just a little off in weight bias. PROOF ------> MY TRUCK IS FUN TO DRIVE Enjoy
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
Young Gun wth Fast Inline
So what have you removed from your truck to make it that light? Removing 100 pounds can make quite a difference when you cant add torque.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Most of the weight reduction is from my LS1, all-aluminum engine. That 200 lbs right there. Getting rid of the truck, 4-speed trans was a lot. The stock trans crossmember weighed a ton too. I also have roll pans and no bumpers.
That's about it.
I just weighed my truck with a full tank on truck scales here in Houston and was quite impressed that I came up at 3800 pounds. I figured I would be over the 4000 pound mark. That is with the regular 350 on a short step. I thought it was pretty good, all things considered!!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Feb 2000
Both of those numbers sound great, especially considering mine was weighing in at 5760 when it had the small block. Guess it will weigh a bit more with the BB, but that's okay.
I'm just amazed you have it lighter than your Camaro, that has to = smiles.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
CCRider
FYI...The 70-82 camaro/firebirds started out in 70 around 3200 lbs...when they quit making them in 82 a fully optioned one was over 4000....mostly because of the government mandated crash stuff
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
