Old 12-18-2013, 08:52 PM   #1
littlevictories
trans range sensor connector, glued in?
Hey folks,
Longtime lurker, first time poster.
Gathering bits and pieces for putting a 5.3 into my '66 c-10
My harness came missing the range sensor plugs, and now I see why.
Today in my travels amongst the ye olde junque yardes every 4l60e I found had the plugs glued in. What in the heck? I'm new to these late-model rigs, is this common?
littlevictories is offline   Reply With Quote
Old 12-18-2013, 09:00 PM   #2
72c10suburban
72c10suburban's Avatar
Re: trans range sensor connector, glued in?
Welcome
Mine were. I was able to wiggle them lose with a little gentle persuasion from a flathead screwdriver. Someone posted though about using a heat gun to loosen up the glue which probably be the best bet.
72c10suburban is offline   Reply With Quote
Old 12-18-2013, 10:44 PM   #3
whiskeywayne
whiskeywayne's Avatar
yes use a heat gun or hair dryer, all you need is a little heat to loosen the sealant in the connector's, had many over the years at a GM shop, I think GM had tsb on this procedure, also if you need to reuse the switch or connectors, heat before reassembly
1950 Chevy 3100
whiskeywayne is offline   Reply With Quote
Old 12-19-2013, 01:18 AM   #4
Angryman117
I used some brake cleaner on mine, let it sit a few and pulled out very easy.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 12-19-2013, 01:30 AM   #5
informi
Sounds like we have the same problem. I am putting a 6.0 in my 62 and my plug was cut out of the harness as well. I am curious which yards you were looking at in Portland. I too am on the lookout for a decent 4l60e.
informi is offline   Reply With Quote
Old 12-19-2013, 11:14 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Removing those connectors is one of the worst parts of an LS swap. haha.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-20-2013, 01:00 PM   #7
littlevictories
the sherwood u-pull-it had an '01 silverado that i took the sensor and plug from. it was put out that morning and the engine was gone by the time i got there.
trans fluid looked like red milk so I passed on it.
I am beginning to think that looking for a 4l80e is a better bet.
Or rebuilding a Gen II "298mm" 4l60e into a compatible "300mm" unit.
this is one of the things my old man warned me about when i started talking about the LS swap. it'll be worth it though.
Thanks for all the replies y'all. Next time I'll have my trusty heat gun unholstered and at the ready.
Old 01-03-2014, 12:10 PM   #8
littlevictories
just about done with the harness modification for stand-alone
since my trans range sensor was cut, i'm having a hard time figuring out which BLK/wht wire goes to which plug.
one BLK/wht wire goes to a ground splice pack, and the other goes to blue PCM connector #32, range sensor input A.
which one goes to the large plug, and which to the small?
Thanks fellas.
-doug
Old 01-03-2014, 03:14 PM   #9
72c10suburban
Hey Doug, just checked my harness. Blue 32 goes to the small white plug on my 05 harness.
Old 01-03-2014, 05:17 PM   #10
Angryman117
I used the PNP C1 picture and the cross referenced the circuit numbers/ labels with the ECM pin-outs listed on lt1swap. I am going to use PNP C2 for my backup lights, safety switch. Hope that helps.
Angryman117's
47 Chevy Build
Old 01-04-2014, 04:43 PM   #11
littlevictories
thats the info i needed, thanks folks!
Old 01-08-2014, 07:41 PM   #12
littlevictories
Just one more, I swear!
Can I run my back-up lamps straight from the F pin on the large plug, or will it need a relay?
Thanks!
Old 01-08-2014, 09:08 PM   #13
truckdude239
truckdude239's Avatar
I had my harness done and they removed that plug my back up light are run off the switch on thevsteering column
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-08-2014, 09:34 PM   #14
ls1nova71
ls1nova71's Avatar
Thanks!
That's the way I have mine wired, no relay since the factory didn't have one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-08-2014, 09:45 PM   #15
Angryman117
Don't see why that would not work. I will dig out my multimeter and see what I can come up with.
Angryman117's
47 Chevy Build
Old 01-09-2014, 12:30 AM   #16
Angryman117
Just did some testing with the multimeter and when I put the transmission in reverse it closes the circuit between pins C and F, so yes you can run the backup lights off that circuit. Don't see why a relay would be needed.
Angryman117's
47 Chevy Build
Old 01-09-2014, 08:17 AM   #17
mrhurt73
here is the drawing i did to make it more clear in my head.
hope it helps.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 01-09-2014, 10:32 AM   #18
littlevictories
Good to hear. Great info in here fellas.
Thanks once again!
