Old 01-09-2014, 10:13 PM   #251
mikeleeshields
mikeleeshields's Avatar
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
Looks like after talking to Dave at porterbuilt I'm gonna have to correct my rearend angle, bummer. I'm making a wedge to install between the trailing arm and the axle pad to correct the pinion angle.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 01-10-2014, 01:29 AM   #252
mikeleeshields
Just ordered that last of my gas lines and brake lines to get them all hooked up.
Mike
Old 01-11-2014, 07:31 PM   #253
mikeleeshields
Well I spent the day cutting off my bag perches and axle pads. After realizing having my rear end pointing down at 12 degrees I had to do so. And yes it sucked. Although I did realize that I'm a better welder than I thought. I have them tacked on now in the correct position at 0 degrees. By the way if you decide to get some porterbuilt parts definately follow the directions when they say only tack things in place before finally welding, lol.
Thanks to Nate from porterbuilt for some much needs advice and confirmation.
Mike
Old 01-13-2014, 09:32 PM   #254
mikeleeshields
Well I got the axle pads and bag mounts tacked on. Now I have the correct angles and measurements. So now I can have my driveshaft made.
I also got some gas goodies in the mail today.
Mike
Old 01-14-2014, 09:56 PM   #255
mikeleeshields
Well I fully welded my axle pads and bag brackets on in the correct positions. Should have my driveshaft hopefully by the end of the week.
Mike
Old 01-15-2014, 03:41 PM   #256
afmedic01
afmedic01's Avatar
Originally Posted by mikeleeshields View Post
I went out to check some measurements before taking the drive shaft to the drive train shop tomorrow. At a ride height around 5" the transmission is between 5* and 6 * down. The rear end is around 10* to 11* down. with the rough dimensions that Bennett68C10 gave me and my mock up dims I should have a new driveshaft by next week. I only wish the carrier bearing mount for the center brace was between the ladder bar perches. In order to use the two piece drive shaft I have I will have to weld a brace in.
I'm in the process of tacking on the air bag brackets to the axle. This might be a dumb question, but what is considered ride height? How many inches from the bottom of the frame to the ground? (front and rear if possible) I am running Porterbuilt mild dropmember in both the front and rear mild. Thanks
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611258
69 C10 SWB Fleet(under construction)
350/TH350
Porterbuilt Front/Rear Mild Dropmembers
Accuair e-level kit
Coys C5 22x9, Nitto 555 255/30r22
afmedic01 is offline   Reply With Quote
Old 01-16-2014, 09:07 AM   #257
mikeleeshields
Nate from PB said ride height is typically 5" off of the ground.
Mike
Old 01-16-2014, 09:10 AM   #258
mikeleeshields
Can anyone tell me what style brake caliper this is. I assume it is a late model GM caliper but I can't find the specs anywhere. It is stamped GM 6474177. I just want to make sure I get the correct banjo fitting. I'm guessing it is a standard 3/8" banjo that I can use.
Mike
Old 01-16-2014, 10:04 AM   #259
Hart_Rod
Hart_Rod's Avatar
http://www.speedwaymotors.com/Speedw...iper,1967.html
Hart_Rod is offline   Reply With Quote
Old 01-16-2014, 10:30 AM   #260
mikeleeshields
Originally Posted by Hart_Rod View Post
Thanks Rob. I appreciate it.
Mike
Old 01-16-2014, 02:01 PM   #261
mikeleeshields
Got my fuel pump in and mounted last night. Also got all the fuel lines mocked up to the fuel pump.
Im waiting to get the rearend back under the truck, that way I can install the gas tank permanently and complete my gas lines.
Mike
Old 01-18-2014, 02:25 PM   #262
mikeleeshields
I got my drive shaft today. Hope to get it mounted then cleaned up.
Mike
Old 01-19-2014, 08:14 PM   #263
mikeleeshields
I mocked the driveshaft up again today and it appears to short. I'm pretty sure the driveline shop messed something up. I have to call them tomorrow. This picture shows the slip joint to tranny connection which is over an inch from being in all the way.
Mike
Old 01-19-2014, 08:22 PM   #264
mikeleeshields
This what the slip joint looks like in the rear with the front slip joint pushed in all the way in the front.
Mike
Old 01-23-2014, 06:19 PM   #265
mikeleeshields
Well i just dropped off my driveshaft to driveline shop. They are going to have to lenthen my the front shaft at least one inch. Im sure hoping they aren't wanting to charge me for something they messed up. I am not doing much on the truck with these single digit temperatures. This winter sucks.
Mike
Old 01-23-2014, 10:42 PM   #266
Bennett68C10
Bennett68C10's Avatar
Sorry to hear about your driveshaft issues. It's their screw up so they shouldn't expect you to pay for it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-24-2014, 07:46 AM   #267
mikeleeshields
We will see. They are supposed to call me today.
Mike
Old 01-24-2014, 07:47 AM   #268
mikeleeshields
A buddy of mine is supposed to drop by this Sunday and drop off his hydraulic flaring tool so that I can start to complete my brake line setup.
Mike
Old 01-24-2014, 10:11 AM   #269
Rochlow
This is kinda why I've been working on my own. I can cut it to size and see how it fits in the truck during the process.
The closest drive line shop from is an hour and with the weather/salt on the roads I wasn't about to send my truck down to them.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 01-24-2014, 12:31 PM   #270
mikeleeshields
I hear ya there. I wish I would have just got a chop saw and tacked the thing together then took it to the drive line shop to have them finish it and balance it. Oh well, you live and learn.
Mike
Old 01-24-2014, 01:28 PM   #271
Rochlow
True that.. However, I'm not sure my methods are going to work out any better than anyone else's. I guess it's all trial and error.
Old 01-24-2014, 11:52 PM   #272
mikeleeshields
I talked to the driveline shop today and they added an inch back to my driveshaft on tHeir dime. I was happy to hear that. I'm going to try and work on this beast tomorrow and Sunday some. I think I can finally start to bolt suspension parts down once and for all. Everything has been tight but not secure to date.
I also squared away my driveshaft dimensions thanks to some help from Nate from Porterbuilt. Not only do they have top notch parts but they also have top notch support whether it is Dave or Nate one of them will help you out.
Mike
Old 01-25-2014, 05:42 PM   #273
mikeleeshields
Well the driveline shop came through and fixed the driveshaft on their dime. I was on my way to go get it this morning but I got stuck in my driveway. There was drifts up to my door on my full size truck so I decided to park it and go get it another day.
So I went to the barn and did a much needed cleaning. Too much grinding and cutting lately, left a lot of remnants on the floor. I hooked my rear bags back up today and I couldn't take it so I had to loosely fit the front clip on. I can't wait to get the cab on.
Mike
Old 01-25-2014, 05:45 PM   #274
mikeleeshields
One more shot from the front.
Mike
Old 01-25-2014, 07:29 PM   #275
Bennett68C10
looks awesome
Keith
66 Suburban
IG: bennett68c10
