Old 01-05-2014, 01:48 AM   #1
wildfifty2
New old bed wood
I would like to replace the bed wood in my 1952 half ton truck. The truck has a pretty rough patina to it so I do not want the bed to look new. Looking for some ideas on how to make new bed wood look like it belongs in my old truck. Anyone have pictures of your new old wood? Thanks
wildfifty2 is offline   Reply With Quote
Old 01-05-2014, 02:19 AM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: New old bed wood
I'd like some pics too, but I'm planning to take some weathered hardwood planks or something and maybe just roll some satin sealer on them or just throw them down as-is. I've seen some nice rough-sawn walnut that would look good.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-05-2014, 07:41 AM   #3
mayor31
I was going to paint mine then sand it down in area's to give it the worn look and seal over it
mayor31 is offline   Reply With Quote
Old 01-05-2014, 10:20 AM   #4
S10Fan
Old Heap Driver
I used cedar fence boards for mine, didn't take long at all for them to look "weathered"
Yes, 55 gallon drum cut in half, widened, to cover a bridge notch.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-05-2014, 01:37 PM   #5
wildfifty2
Thanks for the pics Bryan. Does the cedar seem like it will hold up under a load?
Old 01-05-2014, 01:44 PM   #6
S10Fan
Old Heap Driver
Hard to say......My floor is raised (air ride) with steel supports underneath. I've carried 6-8 50lb bags of mulch without any issues. I'd say a stock style configuration would be way stronger than mine though.
Bryan
Old 01-05-2014, 03:27 PM   #7
OrrieG
OrrieG's Avatar
Here is a trick I use when I need to quickly weather wood or weather the cut ends of barn wood. Get a sheet of bare steel. Spray it with vinegar and keep it wet so it rusts really good, they while wet spread paper towels to soak up the moisture and residue. Let the towels dry. Reactivate the towel with a little sprayed moisture and rub into the wood. I learned this from an old time carpenter that did lots of repairs on cabins, etc. and did the trim work on a project we needed "instant weathering" on.
I took a quick look at google and found this method using steel wool and vinegar that works too.
Old 01-05-2014, 06:34 PM   #8
wildfifty2
I took a quick look at google and found this method using steel wool and vinegar that works too. Aging Wood: Vinegar & Steel Wool Solution - YouTube
Thanks Orrie... That technique seems to work well.. Might have to give it a try on some southern pine..
Old 01-06-2014, 01:00 AM   #9
BurgerMan
Another trick I've used is take your gas torch and go over the boards from a distance. It really pulls out the grain and knots. Then sand stain and seal. I've done it before on other wood projects, and plan on doing it when I make my bed.
1977 Chevy K20
1959 Chevy Apache 3200
BurgerMan is offline   Reply With Quote
Old 01-06-2014, 06:58 PM   #10
hard3
cover them in salt water and let sun hit them , will turn pretty quick.when they take the shade you want, rinse them good, spar varnish or clear poly to seal them.
hard3 is offline   Reply With Quote
Old 01-06-2014, 11:14 PM   #11
wildfifty2
Thanks for all of the good tips guys..
Old 01-07-2014, 03:32 PM   #12
Coach529
Coach529's Avatar
I like that look!!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-07-2014, 03:40 PM   #13
Coach529
Coach529's Avatar
I like that look!!!
1949 Chevy 3600
Old 01-09-2014, 10:08 PM   #14
v30crewcab
v30crewcab's Avatar
I wonder if you sandblast them some it might make the grain pop out more also.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-09-2014, 10:38 PM   #15
beanyard
I have been planning this for my truck for a while. We did a rustic weathered wood tables project for a Jackson Hole WY event and we used brand new lumber. We aged it with a 1/2 formula water based stain from Sherwin Williams. It matched the weathered wood we had perfectly.
For my truck I planned to machine the boards then make them more weathered with water and a wire brush with the grain and then I would stain them.
1959 Fleetside Big Window Long Box
Standard Trim soon to be Deluxe
1953 GMC Carryall Suburban
beanyard is offline   Reply With Quote
Old 01-10-2014, 12:40 PM   #16
combinepilot68
combinepilot68's Avatar
I did a bunch of experimenting and found a formula that worked pretty well to age my brand new douglas fir bed boards that I cut and dadoed myslelf. I mixed some good old vinegar along with a bit of muratic acid in a jar along with some steel wool, rusty nails and a few steel washers. The solution sat in a jar for about two weeks to brew.
To apply the solution, I just used a shop cloth and did a very quick wipe of the boards. The etching/aging takes place immediatley and I am happy with the result.
combinepilot68 is offline   Reply With Quote
Old 01-10-2014, 01:45 PM   #17
wildfifty2
Very nice... Did you age the bed strips too or were those original? I will be hunting down some originals at the next swap meet so i do not have to distress a new set..
Old 01-10-2014, 02:25 PM   #18
combinepilot68
Those are the original. They were pretty good shape. But I used the solution on my wheel tubs to rust up the new steel...................
Old 01-10-2014, 08:09 PM   #19
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
i used some original 1900's barn wood.i got mar-k bed strips and put acid on them to help the rust process.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-10-2014, 08:24 PM   #20
OrrieG
OrrieG's Avatar
you could have shipped me the new ones to me and I would have sent you my original 50+ year old rusted patina ones!
Old 01-10-2014, 11:03 PM   #21
wildfifty2
Does anyone know if the bed strips are the same between various years? I know some years have more strips than others but do the punched holes line up? thanks
Old 01-11-2014, 09:56 AM   #22
S10Fan
Old Heap Driver
Not sure.....I'd look up the part numbers for various years and see what comes up. Some folks may have a different number depending on the width boards used. My late model stepper has 4 strips because I used 12" boards.
Bryan
Old 11-27-2014, 10:22 AM   #23
globalstarpdr
My stepper bed floor. I wanted a butcher block look. Used light and dark cedar.
globalstarpdr is offline   Reply With Quote
Old 11-27-2014, 10:24 AM   #24
globalstarpdr
The cutting board bed floor
Old 11-27-2014, 10:25 AM   #25
globalstarpdr
The beginning
