Old 01-11-2014, 11:04 AM   #2
Chulisohombre
Chulisohombre's Avatar
Re: 1970 4x4 K5 late model front diff swap questions
If its Chevy it should bolt right in. Use the original brake lines and add the soft lines from what year truck the axle came out of. I would get new ubolts and check and replace the seals and gear oil. Only difference you may have to relocate the shock tabs to the right location for your truck.
Chulisohombre is offline   Reply With Quote
