Old 04-20-2013, 09:27 PM   #1
68chvy
68 shortbed 5.3 4l60e DBW swap :)
Yessir.. I'm starting this thread to help.. (Show off my work) lol I have a 68 Chevy c10, putting an 04 5.3L 4l60e in it... I had a 350/350 turbo.. I have done lots of research before the build... I got motor/trans PCM harness tac gas pedal for 1300$ motor had 62,000 miles on it... I live in Dallas Texas... These motors are very easy to find... I got a custom grind to cam.. Got some springs and lifters ... Professional valve job... Got the harness modified locally.. Can hook u up w number if interested.. Got PCM flashed from ol boy from lt1tech , quick turnaround.. Real good guys..
Pix coming soon I dropped motor and trans in today and it fits perfect. 5.3 manifolds didn't fit, I'm using dirty dingos and the pedestals that came with the truck when I got it.. Had 350/350... So gonna try the tbss manifolds? What year guys?? Driveshaft fit... Awesome!! Mounting fuel system tomorrow.. Got the vetted filter and a external fuel pump... Have a 18gal tank under bed ( came with truck) for now at least...
68chvy is offline   Reply With Quote
Old 04-20-2013, 09:37 PM   #2
68chvy
Re: 68 shortbed 5.3 4l60e DBW swap :)
Old 04-20-2013, 09:38 PM   #3
68chvy
Old 04-20-2013, 09:43 PM   #4
68chvy
Only letting me one at a time
Old 04-20-2013, 09:45 PM   #5
68chvy
Bat
Old 04-20-2013, 10:55 PM   #6
SS68
SS68's Avatar
did you use the stock oil pan?
SS68 is offline   Reply With Quote
Old 04-21-2013, 02:44 AM   #7
68shortfleet
So the stock driveshaft length fit just fine in the 4l60??
Any chance of getting a picture of the driveshaft in the trans?
68shortfleet is offline   Reply With Quote
Old 07-10-2013, 10:37 PM   #8
68chvy
Yea oil pan fit perfect
Old 07-10-2013, 10:41 PM   #9
68chvy
Ill try to find a pic.. Or ill get one tomorrow.. But yeah I have the adjustable adapter plates.. I set the motor as far as back as I could ..
Old 07-10-2013, 11:32 PM   #10
truckdude239
truckdude239's Avatar
I uzed the dirty dingo mounts with my engine all the way forward mine was 3 inchs to long i went a head and slide the motor and trans all the way back and had 6 inchs taken out of my front shaft.
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 07-10-2013, 11:47 PM   #11
c10seth
c10seth's Avatar
Dude, Subscribed. I wanna see thin thing running.
Seth
c10seth is offline   Reply With Quote
Old 07-10-2013, 11:52 PM   #12
Nathan28
Nathan28's Avatar
Where did you get the motor and transmission from?
68'chevy swb 350/200r4
71’ chevy swb 6.0/4l80e
Nathan28 is offline   Reply With Quote
Old 01-10-2014, 12:35 AM   #13
68chvy
motorandtransfromjunkyard
Old 01-13-2014, 03:04 PM   #14
chevy-fun
chevy-fun's Avatar
you have one clean truck. who did the cam swap for you. an what part of dallas
chevy-fun is offline   Reply With Quote
Old 01-13-2014, 03:10 PM   #15
68chvy
northTexas machine.. I'm inIrving
Old 01-13-2014, 03:12 PM   #16
68chvy
a1 engines and transmission in off Davis and loop12
Old 01-13-2014, 09:26 PM   #17
1911a1
1911a1's Avatar
Far out! more pics of the truck when you get a chance.
1911a1 is offline   Reply With Quote
Old 01-13-2014, 09:38 PM   #18
67 chevelle
67 chevelle's Avatar
Are you running the 350 trans ?
what cam and springs are you using ?
truck looks clean
I had major issues with manifold/headers using cpp's pedestal mounts had to modify a set of pacesetter headers to work , did not want to fork out the coin for dougs headers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-13-2014, 09:55 PM   #19
68chvy
truck looks clean
Im running a 4l60e
I ended up using stock 5.3 manifolds.. had to grind a little on passenger.
side
I'm using the sbc stands and dirty dingo adjustable mounting.plates. I have motor as close as I could to.fire wall
2004, 4l60e, 5.3, dbw, ls swap
