Cam installed, exhaust video
Now we talking! I went from a .555 solid lifter cam to a Big Mutha Thumpr Hyd. Roller Cam
Lift: .533"/.519" Duration: 299°/319° Lobe Separation Angle: 107 Exhaust - Clear Image headers dumping into Magna Flow S/S exhaust with cross over ![]()
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
Re: Cam installed, exhaust video
Sounds nice!!!!
Looks and sounds great! Congratulations!
1970 SWB Build |
That's awesome Looks and Sound. What all have you done to the motor?
Thanks! Here are some specs
355 cid Chevy (350- 4.030 bore) 10.5 to 1* Speed-Pro flat top pistons (2 valve relief) Big Mutha Thumpr Hyd. Roller Cam Lift: .533"/.519" Duration: 299°/319° Lobe Separation Angle: 107 World Products iron heads w/Comp springs and retainers 1.5 ratio roller rockers Std. rod and main bearings Performer RPM Air-Gap intake manifold, ported Coated Clear Image headers Magnaflow stainless steel exhaust with X Pipe Holley 650 double pumper carburetor MSD pro billet Distributor and Digital 6AL Ignition box Built 200R4 Overdrive Transmission, billet cooler and Hughes trans pan 3:73 gears with Detroit Tru Track rear end with Aluminum rear end cover TCI Breakaway 2800# Torque Converter
![]() Join Date: Dec 2006
Sounds great and your truck is beautiful
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#7 | |
![]() Last edited by MashTheGas 72; 01-14-2014 at 01:15 PM. |
Moderator
![]() Join Date: Jun 2008
Sweet sounding truck! I moved this to the Racing and High Performance area for you.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
mini truck racer
Sounds great
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Hey Expat. How is the power with this Cam. I've heard there just for sound. I was looking to by one myself, but didn't know about the power issue. Boy it sure sounds awesome.
Seat of the pants it feels just as strong as the solid cam set up. It sure revs better!
That's great to know for sure. I'm definitely looking into that setup. Thanks for letting me know.
