Old 01-13-2014, 08:12 PM   #1
SCHRUMGMC
SCHRUMGMC's Avatar
Truck runs ad then shuts off
Went to crank it up and it ran for a minute but then died on me.I'm sorta thinking its the Regulator or the Carb
Any ideas?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-13-2014, 09:35 PM   #2
DransportGarage
DransportGarage's Avatar
Re: Truck runs ad then shuts off
Fuel pump diaphragms get brittle and then die. Rust collects in the tank, then jambs the filter. Dirt gets in the carb and fuel quits flowing. Mice eat the wiring. Without more data, who knows? Did the truck sit for 10 years? 10 days? Give us a little more to work with.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-13-2014, 09:39 PM   #3
57chevyman
57chevyman's Avatar
it ran for a whole minute and then died? or do you mean it ran for a few seconds? .
you have gas in the gas tank right? lol
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 01-14-2014, 03:38 AM   #4
SCHRUMGMC
SCHRUMGMC's Avatar
It ran good the other day, i have a plastic tank on the bed
1971 GMC Sierra
1959 GMC 100
Old 01-14-2014, 09:49 AM   #5
57chevyman
57chevyman's Avatar
Need more details. Maybe in NC it was a cold day and your truck just has to warm up before it will idle without stalling . Gotta figure out if there's something wrong before you fix it.
After your truck shut off, can you crank it , or not ?
Frank
1957 Chevy 3100
Old 01-14-2014, 11:33 AM   #6
SCHRUMGMC
SCHRUMGMC's Avatar
yeah it takes a sec for it to
1971 GMC Sierra
1959 GMC 100
Old 01-14-2014, 11:24 PM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
Took the Fuel fiilter off, it was clogged and dirty
1971 GMC Sierra
1959 GMC 100
Old 01-15-2014, 12:39 AM   #8
mr48chev
mr48chev's Avatar
You may go through several fuel filters before all the trash is cleaned out of the system. I end up doing that every time I get a rig running that has been sitting for a long while.
My ongoing truck projects:
Old 01-15-2014, 12:44 AM   #9
SCHRUMGMC
SCHRUMGMC's Avatar
I'm hoping its something small.It dies when i gas it
1971 GMC Sierra
1959 GMC 100
Old 01-15-2014, 01:07 AM   #10
DransportGarage
That could be the accelerator pump in the carburetor. Also, some fuel filters will let crud past them once they get clogged. This will let the crud get into the carb. Do you know when the carb was last rebuilt?
More possible fun... If the filter is clogged because of rust in the gas tank, the tank will need attention.
Bob
Old 01-15-2014, 01:18 AM   #11
_Ogre
_Ogre's Avatar
you should have one of these before your fuel pump to keep trash out of the teeny tiny check valves in the pump.
shop air compressor timer
Old 01-15-2014, 01:26 AM   #12
DransportGarage
Great idea to get a clear one. Then you can see how fast things are getting clogged up.
Bob
Old 01-15-2014, 02:52 AM   #13
SCHRUMGMC
SCHRUMGMC's Avatar
The current Filtter is glass, truck doesnt have a tank
How much do those run for?, also i'd be lost on how to set one up
Recently looks to be in great shape
1971 GMC Sierra
1959 GMC 100
Old 01-15-2014, 10:10 AM   #14
whammer33024
those filters are like 3 bucks at any auto parts store
whammer33024 is offline   Reply With Quote
Old 01-15-2014, 08:49 PM   #15
SCHRUMGMC
SCHRUMGMC's Avatar
I'll see what I can do , I just hope its nothing major
1971 GMC Sierra
1959 GMC 100
Old 01-16-2014, 01:31 AM   #16
meter swinger
meter swinger's Avatar
If its glass and not plastic its a malatov cocktail. Get it off there asap. I forget who but a forum members truck burned from one of those glass filters.
meter swinger is offline   Reply With Quote
Old 01-16-2014, 12:32 PM   #17
SCHRUMGMC
SCHRUMGMC's Avatar
How would i hook up one then??
1971 GMC Sierra
1959 GMC 100
Old 01-16-2014, 01:34 PM   #18
55metalmonkey
Ditto:
I've seen quite a few nice cars go up in flames due to a glass filter.
I would pull the tank, flush it, put in new fuel and swap out the filter. It's fairly easy to install with a bit of rubber hose and clamps.
If it still stalls after a minute or when you hammer the gas pedal you might have some gunk that got into the carb. I'm a big fan of Seafoam for flushing out the fuel system which will occasionaly clear out the crud but if that doesn't fix it a carb overhaul to clean out all the small orfices may be in your future
55metalmonkey is offline   Reply With Quote
Old 01-16-2014, 09:04 PM   #19
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks bud.There isn't anything bad in there
1971 GMC Sierra
1959 GMC 100
Old 01-16-2014, 11:31 PM   #20
_Ogre
_Ogre's Avatar
before your fuel pump. the glass bowl is after your fuel pump.
if you have steel line into your fuel pump cut out a couple inches and use rubber fuel line to install the filter.
Old 01-17-2014, 11:48 AM   #21
Mgicm
stupid thought but why do they usually put fuel filters somewhere around the engine? Wouldnt it be better to have it somewhere under the truck not near anything hot? Is it possible to put it just off the tank? I guess it could drip on exhaust which would be the same idea but is it done in engine bay just for convenience?
thanks
Mgicm is offline   Reply With Quote
Old 01-17-2014, 01:07 PM   #22
DransportGarage
thanks
Because fuel lines rust internally and fuel pumps disintegrate internally...
Bob
Old 01-18-2014, 04:14 PM   #23
SCHRUMGMC
SCHRUMGMC's Avatar
I'll be damned the truck accelerate on its own now and if push the Choke back it stops.I did what Orrie told me and like the rest of yall but keeps dying out on me.Somethings wrong with the regulator
1971 GMC Sierra
1959 GMC 100
Old 01-18-2014, 08:55 PM   #24
coralhead
coralhead's Avatar
Yeah, that's probably it.
coralhead is offline   Reply With Quote
Old 01-18-2014, 10:41 PM   #25
Red Foreman
Red Foreman's Avatar
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
