Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-14-2014, 06:32 AM   #1
swamp rat
swamp rat's Avatar
Weld in flip door
I have a gas flip door from an S10 and want to install into my bedside.
I have debated the best way to approach this, should i make a circular hole in the bed side or a square hole? will a square hole be more prone to inducing warpage in the panel?
It was also suggested by my uncle to go buy a hand flanger tool, flange it and bond it in place but i don't really wanna spend any more money unless its somehow superior, already have a mig, any advice? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-14-2014, 07:09 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Weld in flip door
You can buy a cheap flange tool from harbor freight ($40.00) and it would be much easier to cut a square hole than a round one ,measure your insert panel allow 3/4 inch inside and flange the truck panel this will ad ridgidity and prevent oil canning, use a 4 foot straight edge to maintain correct horizontal panel alignment ,cut gas filler panel to fit and tack weld and then check alignment and curveture of the body to maintain proper panel conture ,if correct continue tack weld ,grind , use panel adhesive to fill any gaps , grind , finish with normal body filler and prime/paint . if done correctly should look stock when done , poorly and you'll have a big flat spot on your truck bed ... be patient / measure 3 times and cut once ! You'll get it just take your time and do it once. none of this can be done in a COLD garage 70 degrees and up . With the correct tools and materials a good compressor and attention to alignment this is a 2 hour project not including paint prep .That gas door looks pretty flat make sure it has the same conture as the body before you do anything .
Old 01-14-2014, 08:06 AM   #3
MP&C
MP&C's Avatar
Check out this flush mount on an IH Scout. If you could spend the time to make up similar dies to match your fuel door, it may save a bunch of welding (except for hinge, perhaps?) to save all the heat/warping issues in the middle of a panel..
http://www.garagejournal.com/forum/s...d.php?t=208839
Robert
MP&C is offline   Reply With Quote
Old 01-14-2014, 02:10 PM   #4
swamp rat
swamp rat's Avatar
Well i have a little problem then, i'm working in my driveway and i won't see temps in the 70's until August if i'm lucky...
Any more input on this is appreciated, i cant imagine folks in colder parts of the states not getting the work done.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-14-2014, 02:11 PM   #5
swamp rat
swamp rat's Avatar
I keep sayin i wish i had a lath!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-14-2014, 04:32 PM   #6
Grumpy old man
Build a garage first , nothing made for body work is happy below 65 degrees !
Old 01-14-2014, 11:27 PM   #7
Trsmotrhed
Trsmotrhed's Avatar
I did the same fuel door install from a Tahoe. I cut a square out of the side of the Tahoe about an 1" bigger. Cleaned it up, transferred that size to my bed side, cut that out and welded in the donor door panel . Came out great.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 01-15-2014, 12:33 AM   #8
swamp rat
swamp rat's Avatar
It looks great too! Thanks for the reply! Did you have to hand bend the couture a little to get it to match the bedside?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-15-2014, 01:32 AM   #9
Trsmotrhed
Trsmotrhed's Avatar
I looked until I found one that had a little contour. The Tahoe was very close. As you said I did hand shape a little.
63 SWB C10
Old 01-15-2014, 02:06 AM   #10
swamp rat
swamp rat's Avatar
Thanks again Trsmotrhed!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-15-2014, 10:48 AM   #11
hugger6933
First off It needs some warmth in some things for body work but let me just say this I had to heat my plasma cutter the first two days of last week before the PCU would let it turn on and the company had never had one in extremes that cold. If you heat metal and the filler or things similar going on it it will be fine. Now the flange tool, the only thing I use mine for is the opposite end of that head is a hole puncher and I can make the start of some spot weld holes with it. Once I have punched a panel I take a step drill bit and open the holes a couple more sizes to make a decent sized spot weld hole. That is the only worth I have found with that tool. If you put a flange on there no matter what you do to the body or how good your work is it will leave a shadow line of the flange. It also provides a trap for rust and isn't that what we are trying to get away from on these old trucks? Jim
hugger6933 is offline   Reply With Quote
Old 01-26-2014, 12:20 PM   #12
thelonerife
thelonerife's Avatar
Did I mess up by making mine round?
thelonerife is offline   Reply With Quote
Old 01-26-2014, 01:51 PM   #13
Trsmotrhed
Trsmotrhed's Avatar
That looks pretty good to me.
63 SWB C10
Old 01-26-2014, 01:58 PM   #14
swamp rat
swamp rat's Avatar
Did you mess up? Keep posting more pictures, show a shot from the back looking forward, Looks good to me.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-26-2014, 08:22 PM   #15
MP&C
MP&C's Avatar
I've found that having a consistent width of your "inset" panel to the door opening, without having any sharp corners, will provide best results. For a square door, a square cutout with radiused corners, and for a round door with finger tab like you show, the egg shape is about perfect. For a completely round with no finger pull, a round cutout. Weld dots, planish, grind, repeat..
Robert
Old 01-26-2014, 08:40 PM   #16
swamp rat
swamp rat's Avatar
I'd love to see more pic's as you go as far as filler tube, mods ect.
I'm planning on having the center line of the door on the same plane with the center line of the marker lamp
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-26-2014, 09:48 PM   #17
LONGHAIR
I don't think so, especially for a round door.....I would put significant rounding on a square opening too. I would avoid "points" on patches of any shape.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-28-2014, 10:23 PM   #18
thelonerife
Thanks.
I'll post more in my build thread below
So I guess I didn't mess up. It 's hard to planish with the inner panel in the way.
Check out my build thread. I'm sure I'll put it in there.
I thought about that but I wanted to get it as low as I could so the tube in the bed wouldn't be so big.
Thanks for your input. I have aftermarket bed sides and of corse the metal is thinner than original. I am battling flat spots. I got two out tonight but I'm not done welding it in. I weld,then blow it with an air hose, and go to the opposite side and weld blow, repeat.
Old 02-05-2014, 07:50 PM   #19
amberkalvin
amberkalvin's Avatar
I'm a semi noob when it comes to sheetmetal fab but I do know (from going to wyotech for street rod custom fab) that square points have a tendency to suck in more than going with a round shape. I imagine if and when I do anything like this I will always run with something circular in shape.
Looks good! Keep it up.
1984 SWB C10 (http://67-72chevytrucks.com/vboard/s...d.php?t=687521)
1976 K5 super rusty fitech truck(http://67-72chevytrucks.com/vboard/s...d.php?t=740582)
The one I'm keeping forever (Fingers crossed!)
1989 Suburban 2500 L83 6L80
(https://67-72chevytrucks.com/vboard/...d.php?t=818822)
amberkalvin is offline   Reply With Quote
