Old 12-19-2003, 02:51 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
C Notch Question
Being new to this Chevy truck world and learning the applicable terminologies it is nice to see pics posted so I now know exactly what "C Notching " means. Now for my question. I have a 72 Long box with coil springs and I want to do a 4inch drop on the rear and 2 1/2 in the front. If I do not C Notch the frame will my axle hit the frame all the time.
Old 12-19-2003, 03:52 PM   #2
Already Gone
I Forgot
I forgot to mention that I have 235/75 r15 tires on 15 x 8 stock Chevy rallye rims and plan to run 17 inch tires with about the equivalent width and high or slightly taller and wider.
Old 12-19-2003, 04:24 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Well, tire/wheel size is really irrelevant regarding your question. You'll be fine with a 4" drop and no c-notch. Some guys are running 6" rear drop without a c-notch with no problems.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-20-2003, 03:12 AM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Well, I have a 4 inch rear drop and I have only hit the bumpstop on the frame once... Well I actually rode on the bumpstop I had 20 8 foot treated 4x4 posts in the back of my truck. I had to do it for a job I was doing. But to answer you question you will be fine with a 4" drop. Slammed67 is right there are a few guys running a 6" drop with out a notch in the frame and, they haven't had any problems.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 12-21-2003, 12:37 PM   #5
Already Gone
Thanks for the help and advice. I'll try it without and if it becomes a problem deal with it then.
Old 12-21-2003, 03:11 PM   #6
jamis
F.A.S.T. president
jamis's Avatar
I have a 7" drop and did a c-notch, I dont know if a really need it. But since I'm doing a frame off, I thought this would be the best time to do it incase I want to go a little lower later.
So if you have your truck already apart like mine it might not be a bad idea to do it now while its easy.
jamis is offline   Reply With Quote
