stripped neutral safety switch screws?
Hey guys
So today, i started working on undoing another one of the previous owners "modifications" ![]() he put in a non-tilt van auto column when he replaced the manual trans and bypassed the neutral safety switch. few weeks back, i found out steering wheel nut is stripped, but i found out today that one of the screws holes that holds the safety switch is also stripped no idea why he picked this column anyway to fix this? bigger self-tapping screw? anyone know the screw size that holds the switch to the column? i could take the whole thing out and weld it and redrill the hole, but i may as well go get a van tilt column and fix the steering wheel shaft too... maybe im being too anal... the one screw seems like it holds pretty snug? leave it? thanks! Last edited by jks67ss396; 01-15-2014 at 12:57 AM. |
The Older Generation
Re: stripped neutral safety switch screws?
I think it is a #6 x 1/4" or 3/8" long hex head. Pretty small. I don't see any problem going to the next size up. LockDoc
Moderator
![]() Join Date: May 2007
I'd use it as an excuse to get a van tilt. Your intermediate shaft is already collapsed so it will bolt right in. You can extend the wires to the NSS, or use a dremel and relocate it further down the column. A tilt column and a smaller diameter steering wheel greatly improves your driving comfort. If it's not in your budget id just do what Leon suggested.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
