Old 01-14-2014, 10:10 PM   #1
diver
stepside brace part number?
part number or name of brace on top of bed behind driver on front bed panel to support tire carrier.thanks BUTCH
diver is offline   Reply With Quote
Old 01-15-2014, 11:11 AM   #2
wayno
Re: stepside brace part number?
hey butch - I think there are two braces - one long one.... and one short one seen in this picture. They are both in the box that I am sending your way. Unless I am forgetting one I think those are the only one's needed to attached the tire carrier.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 01-15-2014, 11:31 AM   #3
diver
is there one on front of bed top behind driver the 20.oo was for kids birthday thanks
Old 01-15-2014, 12:12 PM   #4
wayno
You are too kind... just the kind of guy you expect to find on this forum. I already sent it back to you so put it into the truck it's free money now . If you have a picture of the brace in question I must have it around here somewhere as that bracket was on this truck when I got it... I'll happily send it on down to you.
Old 01-15-2014, 09:16 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 01-15-2014, 10:16 PM   #6
diver
gm call it # 13 or bracket asm now finding one. thank you for the information BUTCH
Old 01-17-2014, 09:16 PM   #7
wayno
So butch the long brace towards the front of the bed that you see to two arms attach to and then a third arm attaches on the top - that brace is the brace on the right in my picture above and I did send that along to you... I know that's the one that was on that outside front because the truck was yellow and would have been exposed to the exterior paint. The other short stubby one goes to the rear above the fender I believe and up under the rail if I recall correctly and I think that's essentially it. Maybe someone else with a spare tire can post up there's for you?
Old 01-17-2014, 09:23 PM   #8
diver
thank you for being so help full . Butch
Old 11-19-2015, 09:29 PM   #9
jturner18
I'm looking for the braces under the stepside fender. I think it may be three per side? Any help is appreciated!
jturner18 is offline   Reply With Quote
Old 11-19-2015, 09:59 PM   #10
cv65
cv65's Avatar
theres some on ebay now , stepside braces kinda pricey, I made mine from round stock only needed 2
cv65 is offline   Reply With Quote
Old 11-20-2015, 09:04 AM   #11
jturner18
I guess mine broke, at some point, and the PO took some re-bar (left the original) and welded it together. So I have two, in one location. Just thought I'd put original back on. It's probably not difficult to make, is it. Did you heat the end and beat it flat, and then drill your hole?
Old 11-20-2015, 11:18 AM   #12
cv65
cv65's Avatar
Yea thats exactly what I did ,just measure the old one make it alittle long then heat,flatten,drill the end,maybe a small bend on the end if I remember right.then do the other end and your done. if you have more money than time theirs always these http://www.ebay.com/itm/1960-66-CHEV...JJWWEg&vxp=mtr
Old 11-20-2015, 01:37 PM   #13
jturner18
Thanks for the help CV65!
