68 Chevy C10 Stepside
I'm working on a 68 Chevy C10 and I'm running into an issue with my back bumper brackets lining up on the frame. Anyone have any advice?
Re: 68 Chevy C10 Stepside
check your tire pressure. or maybe the muffler bearings are going out, just a thought...
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
Were the brackets bolted to the bumper when you were doing this? If so I would loosen the bolts and try it. That and make sure they're not swapped side for side.
I had them on the correct sides but my bumper is for the stepside and the brackets are marked for a fleetside......that could be the issue.
the in side brackets should be the same but there is different ones for leaf and coil spring suspension
and welcome to the site!
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
Thanks! Im gonna go to the junk yard for some visual help also........sometimes thats better than these assembly manuals.
