Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-17-2014, 02:34 PM   #1
DaHos
DaHos's Avatar
67-72 Caltrac's ???
Looking for info/opinions on the 67-72 Caltrac's with axle flip and spring choice. Anyone here running them?
I will be running a built 402 Big Block, 400 auto and 3.73 POSI rear and around a 28" Drag Radial to start. I would like to use a 2.5" spindle up front and also looking for a "loose" front coil spring, seems all coils I have found are for stock or lowered setups. This will be installed on a SWB frame. Road maners not a must, just looking at getting some good 60 footers.
Any help? Thx, D'
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-17-2014, 05:14 PM   #2
Super73
Super73's Avatar
Re: 67-72 Caltrac's ???
Is your truck a leafspring rear? If so, Caltracs are great. If your truck is a trailing arm (which is most 60-72 trucks) then caltracs wont work for you at all.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-17-2014, 07:17 PM   #3
DaHos
DaHos's Avatar
Yes leaf rear, hence the ?????
I have seen a few builds on the 73-87 platform, just trying to get an idea of ride height/frame clearance w/flip and no notch. My existing springs and shackles are shot so Id be starting out fresh, all I have seen are people using the factory spring packs.
From what I have gathered a 5 leaf pack is the norm, with the flip I would remove the overload spring. So if I was to have a set of springs made up Id need this info.
I have also read they work great once "tuned". What adjustments are available? (w the bag it was a simple air up or down). On my trailing arm LWB I just added a bag to level the squat and away I went........
Also wondering about rear shock placement as Id have to weld new ones on, I believe Id need to mount them to the front of the tube and keep them as vertical as possible.
thx, D'
1967 C10 SWB
Old 01-18-2014, 01:22 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I don't think Cal-tracs will work with a spring flip. But I could be wrong.
I think a lot of the questions you have would be better answerd by Calvert Racing. Get the info first hand from the source.
http://www.calvertracing.com/index.php
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-18-2014, 01:52 AM   #5
Super73
Super73's Avatar
It might require a different Caltrac bar that what is offered for the truck, but the concept should work. A cars rear is on top of the leafs and caltrac mounts to the bottom of the leaf. It would be the same on the truck.
Most cars run a 26-27" tall tire maybe a 28" if they can fit it. A truck generally will have a 28-30" tire providing a little more clearance from axle center-line. I wouldn't be surprised to see the front spring mount have more clearance as well.
Old 01-18-2014, 02:01 AM   #6
GASoline71
GASoline71's Avatar
Great point Sup! Didn't even consider that.
Gary
Old 01-18-2014, 02:20 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
My 73 works good flipped. 1.67-1.69 60'
Old 01-18-2014, 07:46 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
I know they make the Caltracs for nbs and nnbs axle flips . These trucks are everywhere down here and i see them all the time at the race track .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-18-2014, 12:22 PM   #9
Sixshooter44
Go over to yellowbullet and look in the stock suspension forum. Tons of fast leaf spring cars and super smart people
Sixshooter44 is offline   Reply With Quote
Old 01-18-2014, 06:07 PM   #10
drag80
calvert sells leafs springs and cal-trac bars for a "flipped" setup. Also check out "assassin bars" from smith race craft, they are very popular with the stock suspension/radial tire guys. The best thing is just to call and talk to them about what you want.
drag80 is offline   Reply With Quote
Old 01-20-2014, 04:43 PM   #11
72MARIO
72MARIO's Avatar
I had a pair on my 72 Short box.
I removed the over load spring. Bought the Cal tracks for the flipped rear axel. I welded on new saddles. If I was to do it again I would use a 73 up flip kit. A C-notch is a must for street use there was not enough travel with out. As far as ride quality it drove great. There was no issue with ground clearance with the Cal-tracks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
