Old 01-18-2014, 03:38 PM   #1
Stout Ironworks
Not getting fuel to the carb
Hey guys,
I have a 67 C20 327 engine, I am not getting fuel to the carb. I pulled the line from the tank and made sure it was clear, also cleaned the sock. I then ran a rubber fuel line from the tank to the new fuel pump. I removed the fuel pump and re-installed , just to make sure it was installed correctly and it is. I'm still not getting any fuel.
Could it be the cam that works the pump? Any thoughts on other issues.
thanks,
Stout Ironworks is offline   Reply With Quote
Old 01-18-2014, 03:42 PM   #2
cdowns
cdowns's Avatar
Re: Not getting fuel to the carb
have you checked to see that there is gas in the tank above the fuel pickup level
Old 01-18-2014, 03:47 PM   #3
Stout Ironworks
LOL, yes, I put 5 gallons of gas in just to be sure. It is on the low side, less than a 1/4 tank.
Old 01-18-2014, 04:10 PM   #4
zeldman
zeldman's Avatar
Have you checked your oil level? Possible fuel pump diaphram rupture. Also what carburetor? If Q-jet, look for the little filter where the fuel line goes into the carb.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 01-18-2014, 04:15 PM   #5
Stout Ironworks
Oil level is good, also its a new fuel pump. I believe it is a Q-jet... I pulled the line at the carb and cleaned the filter there.
Old 01-18-2014, 04:23 PM   #6
70LonghornCST
Moderator
70LonghornCST's Avatar
I had this problem once. It turned out to be junk stuck in the fuel sending unit at the tank. I began by disconnecting the fuel line at the carb and sticking the end of the fuel line in a 2 litter bottle. I had a friend crank it over just enough to see if fuel came out of the line. I then began to trace the line back, repeating the process at every hose/line/inline filter (if applicable) connection until I found the problem.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-18-2014, 04:29 PM   #7
midniteblues
midniteblues's Avatar
for some reason or another i've had this same problem in the past also .heres what i did.
first and foremost make sure there is more than enough gas in the tank.
you'll need compressed air.
pull the line from the tank off the fuel pump and place a catch pan/jug under it.
cover your hand over the gas filler neck and poke your air nozzle through your fingers and blow the gas will eventually run out the line. get back over there and reconnect the pump and try it.
just becareful gas is very flamable
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-18-2014, 05:05 PM   #8
Stout Ironworks
Well, the issue has to be in the tank. I unplugged the fuel line under the cab and stuck it in a gas can, she fired right up. sounds like a tune up is in order, but not bad for not having run in over a decade.
Old 01-18-2014, 05:36 PM   #9
zeldman
zeldman's Avatar
Good find. Sounds like the fuel sock may be dirty and collapsed.
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
Old 01-18-2014, 05:39 PM   #10
Stout Ironworks
yeah, I thought I had cleaned it but I guess its to far gone. I'll have to order a new sending unit, could be worse. Like I said not bad for not running in more than a decade.
Old 01-18-2014, 08:32 PM   #11
cdowns
cdowns's Avatar
you might want to pull the gas tank out and at least clean the loose stuff out that has resulted in your blockage/// failure to do so will result in a blockage in your new unit
Old 01-18-2014, 10:21 PM   #12
zeldman
zeldman's Avatar
And save the float for the sending unit. Some of the new ones can be pretty poor quality.
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
